Go to Post Most of us are pretty friendly. - StephLee [more]
Unread 23-01-2004, 15:49
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Question Backup/EDUBot Battery
Can someone tell me the mah of the 7.2 volt batteries?
If not at least the Rating of the charger for it?
Thanks,
Phil
Unread 23-01-2004, 16:12
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Backup/EDUBot Battery
Thanks,
Phil
http://www.innovationfirst.com/FIRST...004-Jan-14.pdf check page 5, i hope that helps.
[edit] http://www.innovationfirst.com/FIRST...electrical.htm you can buy the charger there. [/edit]
-Michael Dessingue
Unread 24-01-2004, 09:36
Al Skierkiewicz Al Skierkiewicz is online now
Phil,
I am going to go out on a limb here...
I have tried determining the maHr rating but have little succes so far. I am guessing from the size of the cells that we have a 1300-1500 maH battery. I have a little more investigative work to do today and I will let you know if I find something different. What I am hoping for is a relaxation in the robot rules to allow a larger 7.2 volt battery on the robot. If anyone is running a servoes they are going to deplete that little one pretty quick.
Unread 25-01-2004, 10:55
Phil_Lutz's Avatar
Phil Lutz
#0851 (Froggers)
Originally Posted by dez250
The only info here is the current draw and voltage. The mah figure I'm looking for would be the milliamps per hour (mah) discharge.
We finally found our charger for the EDUBot, so I'm okay now. Rating in 500 mah
I have a Quick charger that I use for charging my R/C Plane b\atteries. By knowing the rating of the battery you can charge the battery "Peakcharge" and get the most out of the battery.
btw you Peak charge NiCad batteries at 2C If you have a 500mah battery you set the charger to 1000mah and when it's finished you truly have maxed the capacity of the battery with no damage.
Thanks,
Phil
Unread 25-01-2004, 18:48
btw you Peak charge NiCad batteries at 2C If you have a 500mah battery you set the charger to 1000mah and when it's finished you truly have maxed the capacity of the battery with no damage.Thanks,
Phil
Phil,
I examined our kit and found a tag that said 800 maH. A lot smaller than I thought. If you have a 500 maH then there may not be any consistency in what has shipped with the EDU kits. The good news is that the rules allow you to use any 7.2 volt battery for the backup. In reference to the Peak charger...That is one in which there are pulses applied to the battery at 2C not continuous at the higher current, right? I have read that charging above 1C is OK for the battery for the first 70% of charge but that degradation sets in after that due to the heat and venting.
Unread 26-01-2004, 19:14
Phil_Lutz's Avatar
Phil Lutz
#0851 (Froggers)
Originally Posted by Al Skierkiewicz
Phil,
I guess you got lucky with the 800mah.
The charger I use is the same one I charge my sialplane batteries with. It handles 1-12 cells and 200-2000mah. It does protect the batteries by switching to trickle (10%) after 90 minutes. I have yet to have a battery go bad using it. Check out www.HobbyPeople.net it's the PF-12 charger. (PF = Park Flyer
Unread 27-01-2004, 07:22
I checked out the site and the charger does look pretty good. It appears to have the right idea in that it cuts back after a set time. I like that it can charge two batteries at once. The description implies that it is checking the battery for peak charge and then switches to trickle. If that is what it does, that follows what I have read is recommended practice. Thanks!
Unread 27-01-2004, 22:56
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Thanks,
Phil
The battery is ~800 mah. You can charge Nicad batteries at 10% of their amp-hour rating, 80 ma in this case, and leave them on charge at that rate for days without hurting them. The chargers that come with r/c equipment for model planes are this type of "trickle plus" chargers. I've used them for my r/c equipment for almost 30 years with very good results.
Team 1062, The Storm, 2003
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
Weigh in with or without battery Joe Clohessy Rules/Strategy 33 21-09-2003 20:31
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
