Go to Post Even though others have had success, I will be honest, this method sort of creeps me out. - Joe Johnson [more]
Unread 23-01-2004, 17:55
AlphaOmega870 AlphaOmega870 is offline
AKA: Mike
#0870 (Southold RICE)
AlphaOmega870 is an unknown quantity at this point
Send a message via AIM to AlphaOmega870
is there a problem with...
for ( n = 1; n =< 150; n++; )
this line of code?
I continuosly get a syntax error with this line and can find no problem with it. Thank you in advance.
Unread 23-01-2004, 18:03
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Re: is there a problem with...
this line of code?
A for loop only takes 4 parameters, you've got an extra ';' at the end. It should be
for (n = 1; n =< 150; n++)
Unread 23-01-2004, 18:28
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
this line of code?
Err ... aside from the mentioned extra semicolon at the end, unless my memory has become severly skewed, I do believe you mean "<=" for less than or equal to, as opposed to "=<". But why such wird code? I mean, really, who starts counting at 1? (Besides normal people, of course
Traditionally, though, you'd say
for (n=0; n < 150; n++)
This is because C starts indexing at 0, like most sane languages. You can also avoid having an equal sign in the for loop. I suppose it is a matter of taste, though ... (and what you do with n within the loop)
Unread 23-01-2004, 19:39
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
and do make sure that you've declared 'n' as well but the main problems are probably those already pointed out, i.e. it should be <=, and there should only be 2 semicolons.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 23-01-2004, 20:09
Guest
Posts: n/a
I hope you meant "3" parameters, not 4
Unread 23-01-2004, 22:33
echos's Avatar
echos echos is offline
Jack of all trades
#1125
echos will become famous soon enough
Send a message via ICQ to echos Send a message via AIM to echos Send a message via MSN to echos Send a message via Yahoo to echos
just thought I would emphasize on this for the n00bs.
 for (n = 0; n <= 150; n++)
 // For statements are a type of loop for exuting a snipet of until
 // it evalueates to false. In the above statement the structure goes
 // as follows. The first part is the intial variable settings before
 // looping, the secound part is the testing part, and the third part is
 // what to do after every loop.
// The following example will loop 150 times before evaluating to false
// or 0 ending the loop.
// code
another variation
n = 0
while(n <= 150)
// Simular to the above statement except that this uses a "global"
// variable which can be called other places in the program.
// code
n++;
Unread 24-01-2004, 01:04
Software guy
Oh boy, that's what I get for trying to do work and read CD at the same time. Hopefully I didn't make such stupid mistakes on my real code
Yes, I meant '3' instead of '4' and I guess I also missed the '=<'. Sorry, and thanks for noticing my mistakes.
Unread 24-01-2004, 10:30
bheller bheller is offline
AKA: Brandon Heller
#0931
bheller is on a distinguished road
One of your comments is off. Your for loop in C:
for ( n = 0; n <= 150; n++)
will do this:
-set n to zero, run code once
-go back to the for statement, add 1, is n <= 150? yes, so run code twice
-(n is now 150) go back to the for statement, add 1, is n <= 150? no, so stop.
The loop will run 151 times, NOT 150 times. Think of a simpler for loop:
for ( n = 0; n <= 2; n++)
n = 0, execute loop.
n = 1, execute loop,
n = 2, execute loop,
n = 3, stop.
If you start at zero and go to 2, the loop runs 3 times - the final valid number, plus one.
Which is why you typically see for (n = 0; n < 150; n++) instead.
The same reasoning applies to the lower for statement.
-Brandon Heller
// code
another variation
n = 0
while(n <= 150)
// code
n++;
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
joystick problem archiver 2000 12 23-06-2002 23:08
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
