Go to Post FIRST continues their full-frontal assault on mentor's vacation days. - Lil' Lavery [more]
Unread 24-01-2004, 12:37
MechaJag MechaJag is offline
MechaJag is an unknown quantity at this point
Globe Motor Coupling
Need some help with a Globe Motor Coupling. Does on need to be made or did we get one? I've searched through the kit of parts and can't figure out anything. Thanks for any help
Unread 24-01-2004, 12:41
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Globe Motor Coupling
A coupling for the globe motors must be manufactured. It is not provided in the kit.
Be sure to avoid placing any side or axial loads on the globe motor. They're very easy to break.
--Madison--
...down at the Ozdust!
Unread 24-01-2004, 16:10
sligocki's Avatar
sligocki sligocki is offline
Super Intelligent S.O.B.
#1151 (The Hitchhikers)
sligocki is an unknown quantity at this point
Send a message via AIM to sligocki
Question Re: Globe Motor Coupling
My team is also planning to use the globe motors and needs to obtain a conection. Are these sold anywhere? If we machine them, is there anything that we should do? pay atention to? Would the coupling just fit snugly against the axel (sliding on) or is there a better way to secure it? Any help would be greatly appreciated. Thanx
-Shawn Ligocki
sligocki@comcast.net
"Never forget that only dead fish swim with the stream."
- Malcolm Muggeridge
Unread 24-01-2004, 16:55
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
We took a chance today and cut threads in the shaft in the hope of using a threaded connector.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 24-01-2004, 17:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Last year, we machined an aluminum coupling and made it a couple thousandths undersize then heated it up with a torch to keep put it one. It never came off after that and did exactly what it was supposed to. For your application, a set screw or two or a pin or maybe nothing at all will work just fine for keeping the coupling from sliding off.
Unread 24-01-2004, 18:12
Ben.V.293 Ben.V.293 is offline
Ben.V.293 will become famous soon enough
Send a message via AIM to Ben.V.293
i made a coupling for the globe motors the other day for our winch. i started out with a 3" long peice of 5/8" steel shaft. then i drilled a 1/4" center hole into the shaft for the small round peice that comes out of the globe end. i drilled it on a lathe. then i moved onto our mill. its a manual bridgeport mill. i mounted the peice in the rotary chuck and centered the peice to the chuck using a 1/4" drill bit. i just lined it up so that the 1/4" bit in the chuck went smoothly into the center hole in the peice. then i put a 3/16 end mill in and milled away. i dont remeber how far i went in each direction, sorry. When i was done it fit perfectly. i hope this helps.
Lost Red Light Globe team 27 Bduggan04 Off-Season Events 0 18-10-2003 19:05
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
