Go to Post Hey, SHIFT HAPPENS.... - David Kelly [more]
Unread 24-01-2004, 15:24
BrendaB BrendaB is offline
no team (Volunteer)
BrendaB is an unknown quantity at this point
IFI Loader Problems
I loaded my FRC hex file into the robot controller. The first thing it did was scroll for almost 5 minutes. After I closed the window and tried to load the code again, the OI and RC radios stopped interfacing with each other. I reset the RC and the OI and the IFI loader gave me a dialog box stating that it could not find the RC. I downloaded the default code and the IFI loader to my PC, compiled the code again and loaded into the IFI loader. It gave me the same error.
I tried calling IFI but they were not open. Have you encountered this problem? I am still not able to load the default code into the RC with the IFI loader. I really would appreciate any insight and directions (including documentation) that would help me solve this problem.
Thanks SO much
Brenda
Unread 24-01-2004, 20:15
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: IFI Loader Problems
Well, there's a menu option to tell it not to auto open the terminal window. (Options > Launch Terminal (After Download)) Is it the default code?
If you want to reduce terminal messages, search for printf() in your code.
Unread 24-01-2004, 20:28
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Did you make sure it was in program mode? Maybe the battery died? Selected the right com port?
Unread 24-01-2004, 22:45
no team (Volunteer)
Believe it or not, my work laptop was the problem. When I used my personal laptop I was able to load the code with ease. It appears some brands conflict with the RC. This was the case with the PC I use at work. Dave Flowerday of Team #111 suggested I do a hard reset and try loading default code from another PC. Guess what? It worked Thanks everyone!
IFI Loader problems billstu Programming 22 23-03-2004 11:39
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
IFI Loader for Linux rwaliany Programming 7 08-01-2004 01:48
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
IFI Loader on ME LBK Rules Programming 1 18-12-2003 17:49
