Go to Post An awesome unveiling video is not necessarily an indicator of onfield performance. - ToddF [more]
Unread 24-01-2004, 13:58
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Global Constants
I was wondering how I could make a global constant for a trig lookup table.
Unread 24-01-2004, 16:28
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Re: Global Constants
You can use a #define statement in a globally-included header file to create global constants. You can also use extern to define global variables.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 24-01-2004, 16:44
When I use extern would the variable be placed in user memory? I have 2k of data for the lookup tables in the trig (this is very little for the 32k of rom space available) and don't want to put these non changing variables in the ram. A define doesn't help because this is an actual table containing data not just one macro that can be quickly changed.
Unread 24-01-2004, 16:49
Unfortunately the extern will be placed in the user memory so, if there is no other way, you might have to try to minimize your table .
Unread 24-01-2004, 17:08
doy's Avatar
doy doy is offline
#1208 Ex-Lead Programmer
AKA: Jesse Luehrs
#1208 (The Super Critical Axe Men)
doy is on a distinguished road
Send a message via AIM to doy
couldnt you declare the table rom? look in the c18 compiler reference guide, i think you could just declare
const rom int trig_lookup[] = {/*info here*/}
and it will put it in rom... you should probably check on that though.
Unread 24-01-2004, 17:28
Ahhh thank you, it appears that should work out well, now the table won't have to be minimized. Seeings as how I don't have the C Reference available and am not able to attend meetings for now due to Academic problems, would you declare this in the header or the C file?
Unread 24-01-2004, 17:41
doy's Avatar
doy doy is offline
AKA: Jesse Luehrs
you would declare it and define it without extern in one .c file, and declare it extern in all other .c files that you want to use it in.
Unread 24-01-2004, 17:42
Thank you for your time.
Unread 26-01-2004, 20:48
Guest
Posts: n/a
deltacoder already wrote some excellent trig lookup code:
Check the repository: http://nrg.chaosnet.org/repository/i...ral%20C%20Code
Unread 26-01-2004, 21:02
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
note - the code in the repository does not currently utilize the "rom" keyword - it's meant to be compiler/platform independent. I would recommend the addition of the rom and const keywords to the definition of the table array, like so:
const rom unsigned char SIN_LOOKUP[90]
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 26-01-2004, 21:08
I think my trig code will run fine,
It has a lookup table with 1440 16-bit values and my sine and cosine functions take very little hit to performance. The angle I use is also in 16-bit straight from the gyro which makes this whole thing very high precision which will be increadably useful for the new drive style (Arcade) I developed and hopefully will get to test Wednesday.
The reason for so many values is that we have 32k of rom sitting there doing nothing. Infact it would be a much more efficient way to calculate out 8-bit values for your angles and multiply it by a 8-bit number for your hypontenuse then shift right by 8. That essentially does floating point for you without the performance hit. Doing it with 16-bits can be a bit trickier but the same principle applies.
Unread 26-01-2004, 21:12
Computer Guy
AKA: Dav
essentially, that is what my code does - it stores 8-bit values for the sin function, and then returns those. for newer programmers however, there is also an implementation of the base sin() and cos() functions that return a floating point (basically, the lookup / 255).
Unread 26-01-2004, 21:14
Guest
Posts: n/a
Ryan:
Can you post your code at the repository? (You'll need to register)
Unread 26-01-2004, 23:00
Posted the code but plum forgot to describe how the values in the table should run, basically they should run something like this, borrowed the table from deltacoder to show as an example. The table can be generated by using
ti=cos(PI / 2 * i / M) * 255
where ti is the table element, i is the element number and M is the number of table elements
cos_lookup_table[90] =
{ 0, 4, 9, 13, 18, 22, 27, 31, 35, 40,
44, 49, 53, 57, 62, 66, 70, 75, 79, 83,
87, 91, 96, 100,104,108,112,116,120,124,
128,131,135,139,142,146,150,153,157,160,
164,167,171,174,177,180,183,186,190,192,
195,198,201,204,206,209,211,214,216,219,
221,223,225,227,229,231,233,235,236,238,
240,241,243,244,245,246,247,248,249,250,
251,252,253,253,254,254,254,255,255,255 };
Unread 07-02-2004, 10:51
Darkman_X000 Darkman_X000 is offline
Darkman_X000 is an unknown quantity at this point
What exactly do you mean by "globally-included header file"? When you use #define to create a global constant, it does not have a type. Do you have to typecast it whenever you use it?
For example:
user_routines.c
#define axelWidth 1234
void fn(void)
x*=axelWidth;      //Can it be this?
x*=(int)axelWidth; //Or must it be this?
x=x*(axelWidth);   //This seems to be the only form that the compiler likes
In C++ you can declare global constants using const varType varName = initialValue; Is this acceptable in C?
Please clarify!!!
Slightly humorous story about global warming & space explor. archiver 2001 3 24-06-2002 04:01
'IT' info... archiver 2001 19 24-06-2002 01:58
