Go to Post "Don't make me call my flying monkeys..." - Joe Johnson [more]
Unread 24-01-2004, 18:22
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Programming joysticks
Originally Posted by NoRemorse
On the new joysticks, there is a mini - milt-direction "d-pad" i guess you could call it. How do you prgram this, or can you even. I can't find it anywhere in the code
It's called a "hat switch" and it'll show up as one of the analog joystick values to the robot controller. I can't remember if it appears as "Joystick Wheel" or "Joystick AUX" off the top of my head, though.
Unread 24-01-2004, 18:36
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
well, the count of buttons on thejoistick does not equal the count of buttons in the program. and it is the odd man out.
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 24-01-2004, 19:14
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
The joystick's POV hat takes the place of the "pN_wheel", where N is the number of the joystick port you're using. I can only really speak for the joystick which I have right in front of me (the other is at my house, being used to play TIE Fighter ), so YMMV. The two least significant bits of the value change too erratically to be of any use. Here's a listing of the values of the variable when the POV hat is in different positions:
Neutral: 001011xx
Up Left: 111111xx
Up: 111111xx
Up Right: 111111xx
Left: 011000xx
Right: 110010xx
Down Left: 101001xx
Down: 100101xx
Down Right: 110101xx
The x's take the place of the two least significant bits, which, as I said earlier, change randomly (at least with this single joystick).
Basically, if you can understand binary, you can take advantage of the POV hat for controlling your robot.
Hope this helps.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 27-01-2004, 21:21
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Neutral: 001011xx
Up Left: 111111xx
Up: 111111xx
Up Right: 111111xx
Left: 011000xx
Right: 110010xx
Down Left: 101001xx
Down: 100101xx
our values for the joystick concur for the first 6 bits as well. (darn shame there is basically no difference between UL, U, and UR)
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 28-01-2004, 20:53
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
So the bit masks are:
const unsigned char Hat_None = 0x2C;
const unsigned char Hat_Up = 0xFC;
const unsigned char Hat_Left = 0x60;
const unsigned char Hat_Right = 0xC0;
const unsigned char Hat_Down = 0x94;
//Unless values are off, Combos aren't OR'ed
const unsigned char Hat_Up_Left = 0xFC;
const unsigned char Hat_Up_Right = 0xFC;
const unsigned char Hat_Down_Left = 0xA4;
const unsigned char Hat_Down_Right = 0xD4;
This seems a little stupid, but that's life.
Unread 01-02-2004, 23:59
Chris Hleva Chris Hleva is offline
#0905 (Razor Burn)
Chris Hleva is an unknown quantity at this point
Send a message via Yahoo to Chris Hleva
Question Programming joysticks
I have a question, how could I add the right lines of code to make the POV hats work with the new C language this year? Amonst other things, where would I have to define them and map them to the right IO ports to work with the hex/bin input signal?
Unread 02-02-2004, 11:15
Why not #define them, instead of taking up memory?
Unread 02-02-2004, 12:45
Computer Guy
AKA: Dav
example:
if( (p1_wheel & 0xC0) == 0xC0 )
     //hat control is pushed right
else if( (p1_wheel & 0xA4) == 0xA4 )
     //hat control is pushed down-left
et cetera
just use the bitwise AND function (&) to determine if the correct bits are set.
Unread 02-02-2004, 16:59
#0905 (Razor Burn)
Thanks, that helped a lot. I am just starting out with C so i'm still a little sketchy with it.
Unread 02-02-2004, 17:21
Computer Guy
AKA: Dav
no prob. if you want a review on the syntax of C, you could try the various guides in the whitepapers section, or the guide that I'm working on (see the thread in this forum titled "FIRST Programming Tutorial")
Unread 14-02-2004, 23:50
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Originally Posted by deltacoder1020
example:
et cetera
Haven't been on for a while, but here goes (Sorry delta!)
If you push the hat up by your code then it will default to the first conditional statement you put in.
A more correct way might be to do it this way (using constants provided courtesy of Astronouth7303)
switch (px_wheel & 0xFC) {
	case Hat_Up_Left: {
		// ... Code here
		break;
	case Hat_Up_Right: {
		// ... Code here
		break;
	// etc...
	default: {
		break;
Unread 15-02-2004, 23:35
Robert Hafner's Avatar
Robert Hafner Robert Hafner is offline
FIRST Alumni
Robert Hafner is on a distinguished road
Send a message via AIM to Robert Hafner Send a message via MSN to Robert Hafner Send a message via Yahoo to Robert Hafner
Could someone help me out?
What I need is for someone to do out the etc. part of the
et cetera
thing so I can do this right. I'm a tad but slow when it comes to binary and hex
Unread 16-02-2004, 00:05
Computer Guy
AKA: Dav
here they are in binary, decimal, and hex forms...
Neutral: 001011xx 44 0x2C
Up Left: 111111xx 252 0xFC
Up: 111111xx 252 0xFC
Up Right: 111111xx 252 0xFC
Left: 011000xx 96 0x60
Right: 110010xx 200 0xCB
Down Left: 101001xx 164 0xA4
Down: 100101xx 148 0x94
Down Right: 110101xx 212 0xD4
Unread 16-02-2004, 00:17
Guest
Posts: n/a
Here's a diagram that gives the full range of values and the value to test with AND is bold.
252-255*252-255*252-255
*96-99***44-47**200-203
164-167*148-151*212-215
Unread 16-02-2004, 00:20
FIRST Alumni
Because the last bits are unreliable (from what i've read), how will this affect the program? Should I stick with a general area? example:
if (p1_wheel >= 42 && p1_wheel <= 46)
    // I am neutral
if (p1_wheel >= 250 && p1_wheel <= 254)
     // I am upperleft;
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
Could use some help with joysticks . . . archiver 2001 5 23-06-2002 23:36
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
pbasic programming punarhero Programming 4 21-01-2002 23:32
