Go to Post Mentors can either hide the experience of failure or support the right of a student in gaining that experience. - dcbrown [more]
Unread 24-01-2004, 18:38
echos's Avatar
echos echos is offline
Jack of all trades
#1125
echos will become famous soon enough
Send a message via ICQ to echos Send a message via AIM to echos Send a message via MSN to echos Send a message via Yahoo to echos
Random code snipets
I've been working on some perty usless code that are more for fun than anything else, but oh well.
Feel free to post some of your own.
Here they are...
Find Pi
 unsigned double float pi;
 void main(void)
 	pi = 1;
 	for(count = 0, top = 2, bottem = 1; count < 10000; count++)
 		pi *= top/bottem;
 		bottem += 2;
 		pi *= top/bottem;
 		top += 2;
 	printf ("pi = %f", pi*2);
Random Signature
PHP Code:
<?php
 header
("Content-type: image/png");
//read folder
$folder opendir(".");
 while (
$file readdir($folder))
$names[count($names)] = $file;
closedir($folder);
//sort file names in array
sort($names);
//remove any non-images from array
$tempvar 0;
 for (
$i 0$names[$i]; $i++)
$ext=strtolower(substr($names[$i],-4));
 if (
$ext == ".png")
$names1[$tempvar] = $names[$i]; $tempvar++;}
//random
srand ((double) microtime() * 10000000);
$rand_keys array_rand ($names12);
//random image from array
$im imagecreatefrompng($names1[$rand_keys[0]]);
imagepng($im);
Create a directory on your server and put this script there along with any png images. It will select one randomly and then output it to display image. This the exact code that I use for mine. (hit F5 a couple of times to watch it change)
Entity Hosting Staff
http://www.entityhosting.com/
Unread 25-01-2004, 18:25
Guest
Posts: n/a
Re: Random code snipets
Could you add these to the repository?
http://nrg.chaosnet.org/repository - You'll need to register
Unread 25-01-2004, 21:06
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Err ... Could you not add these to the repository? Maybe I got the wrong idea, but I thought the repository was supposed to be a place to find *useful* and *robot-related* code (ideally to spark either inspiration or recognition ). These snippets are useless to any team looking for some code for their robot, and hence would only clutter up the repository -- thereby making it a less useful place, as it would be harder to find what you're looking for.
I mean, really, the poster did say:
Also, I saw in another post that you asked for the beacon/tracker code to be uploaded to the repository. I believe that this would be a mistake, too. This code can be got in other places (it is on the FIRST website, afterall). Anyone going to the repository should already have access to that code, and hence, again, the unnecessary posting of it would only add clutter, and make the repository less useful.
I realize you are excited about getting a lot of useful code uploaded to the repository ... but more is not necessarily better. Especially if it is more uneccesary or useless code! Remember: quality, not quantity, is what counts ... especially when programming. Perhaps I mistook the purpose of the repository ... but it doesn't seem to me like there is a need for a repository of random, un-related and un-useful pieces of code.
Unread 26-01-2004, 01:42
Grommit Grommit is offline
#0115 (Monta Vista Robotics)
Grommit will become famous soon enoughGrommit will become famous soon enough
Send a message via AIM to Grommit
That's a very poor formula for pi. It converges very, very, very slowly.
Try some of these links for some better formulas:
http://www.geocities.com/SiliconValley/Bay/9187/pi.htm
http://elephant.linux.net.cn/articles/pi.php?lang=en
Chudnovsky's algorithm would be a fine choice. You get 14 digits every iteration of the algorithm.
Unread 26-01-2004, 14:46
echos's Avatar
Jack of all trades
#1125
New version of random image
PHP Code:
<?php
// Last Updated: Sunday, January 26, 2004 at 11:43:45 AM
// *****IPORTANT*****
// GIF support has been disabled due to complications
// of another nature.
/* Supported image types                          */
/* Input:                                         */
/* PNG                                            */
/* JPEG                                           */
/* WBMP                                           */
/* XBM                                            */
/* XPM                                            */
/* Output:                                        */
/* PNG                                            */
/* JPEG                                           */
/* GIF (if supported, else defualts to PNG)       */
/* -Options                                       */
/* Image Output type                              */
/* Desription:                                    */
/* Allows the ability to overide the type of      */
/* image output by the program.                   */
/* Settings:                                      */
/* auto, png, jpeg, and gif (if supported)        */
$imageoutputtype "auto";
/* JPEG Quality                                   */
/* Description:                                   */
/* Allows you to set the compression level of     */
/* JPEGs generated by the program.                */
/* Settings:                                      */
/* defualt, [0-100] (0 worst and 100 best)        */
$jpegquality "defualt";
/* NO NEED TO CHANGE ANYTHING BELOW               */
//does a check to see if GD is installed and running
if (!isset(imagetypes()))
    die("This server does not have image support.");
if(!isset($imageoutputtype))
if(!
$jpegquality >= && !$jpegquality <= 100)
$jpegquality 100;
//read folder
while (
closedir($folder);
sort($names);
$tempvar 0;
for (
    if (
$ext == ".png" || $ext == ".jpg" || $ext == "jpeg" || $ext == "wbmp" || $ext == ".xbm" || $ext == ".xpm")
$tempvar++;
//random
$rimage $names1[$rand_keys[0]];
//image identification
$imagetype strtolower(substr($rimage,-4));
//image import
if($imagetype == ".png")
$image imagecreatefrompng($rimage);
    if(
$imageoutputtype == "auto")
$imageoutputtype "png";
  elseif(
$imagetype == ".jpg" || $imagetype == "jpeg")
$image imagecreatefromjpeg($rimage);
    if(
$imageoutputtype "jpeg";
  elseif(
$imagetype == ".gif")
$image imagecreatefromgif($rimage);
    if(
$imageoutputtype "gif";
  elseif(
$imagetype == "wbmp")
$image imagecreatefromwbmp($rimage);
    if(
  elseif(
$imagetpye == ".xbm")
$image imagecreatefromxbm($rimage);
    if(
  elseif(
$imagetype == ".xpm")
$image imagecreatefromxpm($rimage);
    if(
//image output
if($imageoutputtype == "gif")
    if(
imagetypes() & IMG_GIF)
header("Content-type: image/gif");
imagegif($image);
      else
header("Content-type: image/png");
imagepng($image);
  elseif(
$imageoutputtype == "jpeg" || $imageoutputtype == "jpg")
    if(
imagetypes() & IMG_JPG)
header("Content-type: image/jpeg");
imagejpeg($image''$jpegquality);
      else
imagepng($image);
  elseif(
$imageoutputtype == "png")
imagepng($image);
  else
imagepng($image);
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
How random is random???? archiver 1999 0 23-06-2002 21:59
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
