Go to Post If this information is not 100% correct, you should follow the default advice I have for when anything goes wrong: Blame the Programmers - IKE [more]
Unread 24-01-2004, 11:38
Team 869 Team 869 is offline
Team 869 is an unknown quantity at this point
Mplab startup error
We've tried searching but no one else seems to have the same problem. When we run mplab ide a windows error occurs closing down the program. We've tried reinstalling multiple times but to no avail. Any help would be greatly appreciately.
Unread 24-01-2004, 13:50
hello world's Avatar
hello world hello world is offline
hello world has a little shameless behaviour in the past
Re: Mplab startup error
try reinstalling in a new computer. if it is a problem with one computer it should work. if it is the problem with the whole program, try getting a new MPLAB IDE 6.3 cd and reinstalling.
Unread 24-01-2004, 15:28
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
I had the exact same problem. In install, it says to ignore the USB stuff, so once the thing installed I pressed cancel when the USB install stuff came up.
You need to let that finish.
However, if you go into the MPLAB folder and run register.bat in the dlls folder, it will start working with your current installation.
Unread 24-01-2004, 19:48
Thanx guys, I will try what you said Jay. Yea it was weird because it worked on my computer at home. Thanx again.
Unread 24-01-2004, 23:17
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
I had a similar problem when I tried running the IDE on one of our junky old donated computers with Windows 98 (not SE). What OS do you have?
Unread 25-01-2004, 04:30
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
If you're on a LAN make sure you're not running "roaming profiles." I know we have problems with MPLAB and Inventor with that. We'll logon to one computer and run the install and then logon on another computer and run the program that's been installed locally already but it tries to grab our config files from our user directory.
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 25-01-2004, 10:41
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
We have old 98 (not SE) computers and it works fine. Make sure you don't install USB drivers. Also, you will get a message saying that the program might not function right?, but it works fine if you close it.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
If you're having MPLAB problems, LOOK HERE. Jeremy_Mc Programming 0 20-01-2004 18:06
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
Basic Run Error Ulibrium Programming 12 21-02-2002 01:02
