Go to Post The big lesson we learned ... our past does not limit our future, that superior attitude will beat out big budgets. - [more]
Unread 24-01-2004, 11:13
pagemauck pagemauck is offline
pagemauck is an unknown quantity at this point
autonomous code placement
I'm guessing all autonomous code will go in the section marked for it in the user_routines_fast. Are we being stupid putting line tracking code in here since the statements for sensor input like
if(rc_dig_in06 == 0) pwm=255;
don't work for us in this section while a simple pwm=255; works fine
Unread 24-01-2004, 13:33
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: autonomous code placement
not all autonomous code goes in user_routines_fast - anything that is going to be acting on sensor input should probably just go in user_routines, as the sensor input is only updated once per user_routines call. put processing that is not sensor-dependent in user_routines_fast.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 24-01-2004, 20:11
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
If you fell REALLY ambitious, You can modify void Main() so that it runs through everything twice: once for Autonomous, then again for user. The worse that could happen is that it screws with your controller and your robot self-destructs .
Serriously, the only thing you don't download over is eeprom, and that's not really used much (I think). If you just download the regular default code, it should work fine.
It would essentially create 2 programs. I would put Autonomous code in sepperate files.
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous code tutorial miketwalker Programming 2 23-02-2003 12:28
Autonomous code PBoss Programming 7 14-01-2003 15:29
Autonomous Code Adrian Wong Robotics Education and Curriculum 1 18-11-2002 22:34
