Go to Post The Scouting Award exists. It's called "Championship Winner". - Chris is me [more]
Unread 22-01-2004, 17:28
AlphaOmega870 AlphaOmega870 is offline
AKA: Mike
#0870 (Southold RICE)
AlphaOmega870 is an unknown quantity at this point
Send a message via AIM to AlphaOmega870
Question how do you...
create a counter for the autonomous code?
Unread 22-01-2004, 17:35
Kevin Casper Kevin Casper is offline
#0171 (Hardcore Engineers)
Kevin Casper is an unknown quantity at this point
Re: how do you...
What type of counter do you want? Time based? Cycle based? Event Based? Code for a counter?
If it is time based then one of the loops of the program happens every 26ms(I think). Just count the program loops and you have time.
Kevin Casper
Unread 22-01-2004, 18:13
AKA: Mike
Re: how do you...
we want something like last years auton counter.
Unread 22-01-2004, 19:40
Bharat Nain's Avatar
Re: how do you...
How would you create a Time Based counter?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 22-01-2004, 20:20
Mercutio Mercutio is offline
Atticus Finch Wannabe
#1213 (The Grobots)
Mercutio is on a distinguished road
Re: how do you...
Read http://www.innovationfirst.com/FIRST...004-Jan-14.pdf. It'll tell you everything you need to know. Make sure you know the basics of interrupts too.
~Aaron
"If we knew what we were doing, it wouldn't be called research, would it?"
—Albert Einstein
<X3 What can I do? You broke the tie wraps that were holding together my heart. ^_^
Unread 22-01-2004, 22:18
Umm Errr...
Re: how do you...
Don't Do this!! It was the only option last year, but we have much better options this year. Create a timer interrupt that triggers every X seconds(see above whitepaper link), that inctements a variable. Jut read this variable an you have a timer. If you need orther help, just let the peeps here and we can help.
1139 Alumni
Unread 23-01-2004, 15:31
Re: how do you...
From where do you get all these help files and manuals?
-= Bharat Nain =-
Unread 24-01-2004, 19:55
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: how do you...
IFI, mostly.
Unread 25-01-2004, 05:43
echos's Avatar
echos echos is offline
Jack of all trades
#1125
echos will become famous soon enough
Send a message via ICQ to echos Send a message via AIM to echos Send a message via MSN to echos Send a message via Yahoo to echos
Re: how do you...
here is some rather straight forward code, simular to previous years stuff.
 unsigned int counter;
 if(autonmous_code)
 	if(counter <= 20)
 		pwm01 = pwm02 = 255;
 	  else if(counter >= 21 && counter <= 100 && counter != 99)
 		pwm01 = 255;
 		pwm02 = (pwm01 -= 254);
 	  else
 		die(void);
 	counter++;
Entity Hosting Staff
http://www.entityhosting.com/
Unread 25-01-2004, 08:41
Obi's Avatar
Obi Obi is offline
Obi is an unknown quantity at this point
Re: how do you...
 if(autonmous_code)
 	if(counter <= 20)
 		pwm01 = 255;
 	  else
 		die(void);
 	counter++;
Our program (Team #870) looks like that, except that we have counter = 40 x the MS (26.2, but we use 25). We then output that to the IFI loader screen, and we get a nice display, every second, declaring the amount of seconds, whether in Auton mode or Practice.
Unread 25-01-2004, 08:57
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: how do you...
Just like James said earlier in this thread, I highly recommend using something a little more advanced than just incrementing a counter variable every code cycle. The PIC18F8520 comes with 5 seperate timers (the first of which is used by IFI, so we have access to 4). They're pretty well documented in the datasheet for the microcontroller (sections 11 through 15). Three 8bit timers, and one 16bit timer. With all of the capabilities of the processor, itself, I would be very disappointed to see any team counting cycles as a timing system. I'm already forcing my programming mentees to learn about timers, interrupts, and other such features of these nice little machines.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 25-01-2004, 09:30
Obi's Avatar
Obi Obi is offline
Re: how do you...
I don't exactly see the advantage of using interrupts over counting cycles. Care to elaborate?
Unread 26-01-2004, 20:38
Rorschach's Avatar
Rorschach Rorschach is offline
2068 Mentor
AKA: Matt
FRC #2068 (Metal Jackets)
Rorschach is an unknown quantity at this point
Send a message via AIM to Rorschach
Re: how do you...
 if(autonmous_code)
 	if(counter <= 20)
 		pwm01 = 255;
 	  else
 		die(void);
 	counter++;
I know this may sound rudimentary, but where is <i>die(void)</i>, is that the function that the routine is within?
Unread 27-01-2004, 09:21
Re: how do you...
Program cycles will vary as you add and remove code.
The cycles are also variable in general because of other events like interrupts that may be going on asynchronously. So one loop might take 50 clock ticks while the next takes 150 ticks. Over time you can accumulate large variations.
The clock approach always puts you within a few clock ticks of where you expect to be, and errors don't accumulate over time.
