| View Poll Results: What motors do you use for the drive train? | |||
| CIM Motors |
48 | 60.00% |
| Globe Motors |
6 | 7.50% |
| Fisher Price Motors |
10 | 12.50% |
| Drill Motors |
59 | 73.75% |
| Other |
6 | 7.50% |
| Multiple Choice Poll. Voters: 80. You may not vote on this poll | |||
Re: What motors do you use to drive your robot?
We will use either the drills, or the CIMs. It all depends on what we use the other motors for *Wink*
Last year was the only year (that i know of) where we used the CIM motors, and we did have a large and heavy (and poorly constructed) gearbox. This year were reverting to the tried and true drill motors.
Well the past 3 years we've used the drill motors (this year is no differerent). Last year though, we tried a dill/CIM combination which worked pretty well, although they added a lot of weight :/
The Bosch and the Chiaphua are both excellent for driving. The versatility and relative ease of use of the Bosch drill motors for drive applications is unparalleled, and many teams use them for that very reason. They are a safe choice, and a strong choice as well. As Paul Copioli pointed out, we have found the CIMs to be very good in both directions and they are fine even after long use. They are actually usually colder on the exterior after a match than anthing else we've used in recent memory, including the drills and Fisher-Prices. For Fisher-Prices and drills (which clearly aren't meant to be used nonstop and stalling for two minutes), I highly recommend some kind of compressed air cooling spray to use between matches.
Many older teams with the means to build a gearbox do so in order to get CIMs and Bosch drills running together (i.e. four-motor drive). That way they can run at relatively high speeds while maintaining the power they need in order to hold their own. Or even have a transmission in addition to the four motors. Some teams (including 217 in 2002 and 188 for the past two years) mate three motors per gearbox for a whole lot of power. Or at least power drain; by the latter third of a match, these robots tend to be out of juice. Last year we built a simple gearbox that mated the Bosch drills, CIMs, and Fisher-Price motors so that we could run at high speeds and still outpush the vast majority of our opponents. We did have some trouble with our battery voltage dropping low enough to cut out our controller in two matches (one of which being the finals in the Canadian Regional ), but those were very extreme circumstances. While we have used Fisher-Price motors in our drivetrain before, we don't use them by themselves. Depending on the configuration of a robot, in some cases they won't be able to even turn it, and then you'll get the distinctive toasty Fisher smoke and smell. Last edited by jonathan lall : 25-01-2004 at 15:19. |
Team 25 used a combination of Drills and CIMs in the 2003 season, and will do so again in 2004.
Team 356 used the drill motors only in years 2000, 2001, and 2002.
Team 356 used both the Chips and the Drills in our 2003 drive system. They are both excellent motors to use if you pay attention to all of the mounting and cooling quirks. Since 2003's drill motors were so happy to have a friend (the Chips) we thought we'd add another friend for the drills and the chips this year, the Fisher Prices. It didn't occur to me to use the Globe Motors in the drive system. Hmmm. Maybe in 2005. |
#7
Team 116 has a 2-motor, 2-speed gearbox that has worked well in the past, and will hopefully continue to work well for us as we use it again this year. It combines the chipuas and drill motors and the plans are in the white pages on this site for anyone interested.
#8
On the current draw thing, up to a point, as you add motors (especially in the drive system) there is a tendency to balance the load among the motors and run each motor at a lower current draw. |
#10
does anybody know what the max watts of a CIM motor is?
#12
Ok, I will let everyone in on our team secret. We use the globe motors for our drivetrain, and they work great, but you have to give them... ummmm..
special treatment! before each match we soak them in liquid hydrogen to get their core temp down to 3°K, which is almost low enough to become superconductors but once they start to spin, the airflow over the coils causes a windchill factor of -7°K so they superconduct - we get about 4HP out of each one, and once you apply a current to it, it keeps running (because of the supercondution) until you reverse it. Therefor they actaully consume almost no power at all. :c) |
| Shifting Gears | MBosompra | Technical Discussion | 71 | 23-07-2004 02:49 |
| Looking for practice motors & extra tape drive parts? | archiver | 2000 | 1 | 23-06-2002 22:54 |
| WASH Palm scouting at the Championship | Mike Soukup | Scouting | 2 | 19-04-2002 15:14 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| about how Drive Train push the robot... shouldn't the force accelerate the robot? | Ken Leung | Technical Discussion | 12 | 26-11-2001 09:39 |
