Re: Code Repository
it seems that your form is currently pointing to "/repository/slogin.php", while the file is at "/uploads/slogin.php" - this probably isn't what you want. (note - the login form doesn't work either, same error message.
Re: Code Repository
I'm using the <base href="../uploads/"> tag to point to the correct page. Is that supported?
Re: Code Repository
deltacoder,
how did you finally successfully register and login? |
Re: Code Repository
don't depend on it - it's better to hard-reference all of the links. the BASE tag is nowhere near supported on all pages. also, it's good practice to quote all of the attributes for a tag, not just those with spaces.
i registered and logged in on the main page for the team, then switched over to the repository (at least the session carried over) Last edited by deltacoder1020 : 25-01-2004 at 17:34. |
| What is your most prefered programming language? | Hailfire | Programming | 156 | 19-01-2005 21:42 |
| InfraRed autonomous code ... | mtrawls | Programming | 1 | 11-01-2004 00:25 |
| Autonomous code | PBoss | Programming | 7 | 14-01-2003 15:29 |
| Does your team use the Default code. | Jeff McCune | General Forum | 2 | 09-01-2003 14:46 |
| Patent source code? | Kyle Fenton | Chit-Chat | 3 | 20-10-2001 17:53 |
