Go to Post And then since this is GTR-W there's also maple syrup somewhere and the drive team says "Sooory." - PayneTrain [more]
Unread 25-01-2004, 17:07
Guest
Posts: n/a
Re: Code Repository
I'm using the <base href="../uploads/"> tag to point to the correct page. Is that supported?
Unread 25-01-2004, 17:21
Guest
Posts: n/a
Re: Code Repository
deltacoder,
how did you finally successfully register and login?
Unread 25-01-2004, 17:23
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Code Repository
don't depend on it - it's better to hard-reference all of the links. the BASE tag is nowhere near supported on all pages. also, it's good practice to quote all of the attributes for a tag, not just those with spaces.
i registered and logged in on the main page for the team, then switched over to the repository (at least the session carried over)
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 25-01-2004, 17:58
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: Code Repository
Originally Posted by SilverStar
I'm currently implementing a repository at:
http://nrg.chaosnet.org/repository
Spread the word! Note: it is not finished, I'm working on it. And, you HAVE to register an account at the NRG website to be able to post code to the repository.
Hope you like it!
Is it intentional that you can't view code without registering? (Above you just say post code.) Without registering, the 'code' just consists of this:
<!-- nd GOT read1===false -->
/* Downloaded from the NRG repository: http://nrg.chaosnet.org/repository
Program title:
Author:
Date uploaded: Jan. 1, 1970 12:00 AM
Array
Upon registering, though, I could see the code. (And, incidently, registering worked for me -- if you coulndn't tell.)
Unread 25-01-2004, 18:00
Guest
Posts: n/a
Re: Code Repository
Exactly what do you click on? (the whole trail)
'cause it works when I'm not logged in.
(And I was working on it when you saw it, it's fixed now).
I'm starting a seperate thread for the NRG code repository specifically.
Unread 25-01-2004, 18:09
mtrawls's Avatar
Re: Code Repository
Okay. An issue of timing, then. It seems to work fine now. Good work
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
