Go to Post Forget Pool Basketball or Pool Volleyball, it's time for some Pool Rack n' Roll! - Conor Ryan [more]
Unread 14-01-2004, 09:41
Re: Save time? Use aluminum extrusion kits!
these have grooves that allow you to put fastners anywhere along the length - you hook them in and they will slide anywhere - also the end pieces are easy to use
its like a hi-tech erector set - except you are not limited by holes in the metal for placing attachements.
Unread 14-01-2004, 10:17
Loren 930's Avatar
Loren 930 Loren 930 is offline
#0930 (M-Cubed)
Loren 930 is an unknown quantity at this point
Hello Gui -
Hopefully I can answer your question regarding the differences in extrusion systems. My engineering company used many other brands in the past, but because we require performance and value, we settled on the "item" brand (not to be confused with the IPS brand - which is not and has never been the same as "item") extrusions in our shop. As Tim mentioned, there are wide differences in dimensional tolerances and alloy which in turn reflect on the strength of the extrusion. Equally important is the method of attachment - other systems have copied the item fasteners but they do not work unless you have a high strength extrusion to use them in. item has been in business for over 26 years and is the world sales leader in structural aluminum systems. So why is this important to you? It means you get a highly engineered and respected building system with very high level of engineering support. item is committed to staying at the top which is why they have decided to support FIRST teams with an outstanding value in the form of "kits" that contain the neccessary extrusions and fasteners to put together a modular and strong robot. Team 930 has used these kits exclusively for the past two years - and as anyone that has seen our robots will attest too - they are strong, rigid, and light and we have never had a fastener break or come loose. If you or anyone else reading this post has any questions about applying the system to your project, please contact me at loren@aes-wi.com.
Good luck this year - it is a great game!
Loren
engineering lead
Team 930
www.team930.com
Unread 14-01-2004, 10:31
Loren 930's Avatar
#0930 (M-Cubed)
Hello,
As a side note, I would like to clarify what size extrusion is in the kits. The extrusion size(s) - depending on which kit you use - has 20x20 and 40x20 size extrusions. This is the outside dimension size in millimeters. The weight (size 20x20) is 0.48kg/m (approx. .33lb / ft) and the 4th moment of inertia is 0.72cm4 - for those that want to do the calc's - which I highly recommend you do when comparing systems. The pullout strength for a fastener connected in the t-slots is 500N (112lbs.). More engineering information can be obtained at www.item-international.com or contact me at loren@aes-wi.com.
Hope this helps.
Loren
engineering lead
Team 930
www.team930.com
Unread 15-01-2004, 13:01
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
If you're really looking for quality, then you want to go with Bosch 20 mm.
Bosch Rexroth:
3m of 20x20 for $20.00 (no discount)
I = .67 cm^4, (.016 in^4)
W = .4 kg / m, (.269 lbs / ft)
Pullout = 1700 N, (382 lbs.)
Tensile Stress = 250 N / mm^2
Item:
3m of 20x20mm for $25.50 (discount)
I = 0.72 cm^4
Weight = 0.48kg/m (.33lb / ft)
Pullout = 500N (112lbs.)
Tensile Stress of Aluminum = 245 N / mm^2
I'll leave the choice up to you.
It's considerably lighter, just slightly less rigid, about 20% cheaper, and has better fasteners.
Hope this helps. Good luck boys and girls!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 15-01-2004, 13:39
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
I believe Raider Robotix's 2002 robot, Silver Scorpion, used extruded aluminum. That robot was the one that required the least maintenence of all. It practically never broke, or required much more maintenence than a change of battery in between matches.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 16-01-2004, 10:04
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
The Bosch extrusion is NOT a superior product. A local business that builds industrial robots out of extrusion has completely quit using the Bosch because it is notorious for vibrating loose. And on a FIRST robot that is too risky.
Furthermore, some of the numbers you quoted are funny. The pullout strenght of 300+ lbs for the 20x20 is simply impossible according to the tensile strengh claimed. The material will fail and release the fastener before you get to 300 lbs.
The specifications claimed for the item extrusion are from actual test data posted by the manufacter. You will NOT see actual test data for the Bosch. Since in europe--where item originates--manufacturers claims must be absoluetly guaranteed, you will see very conservative estimates of structural strength. In our experience the material can be up to 3 times stronger than claimed in the catalog.
Which is better for a FIRST robot? You have to weigh strength and reliability against your pocketbook... But remember the free market ensures that "you get what you paid for".
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Unread 16-01-2004, 12:55
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Originally Posted by Clark Gilbert
BAH!
I was hoping I could find it here on the forums!! I have a copy of it, but it's on my computer at home, and that computer is no where near being hooked up...
It would make for a good example, but that thing is sooo old now I don't even know if the deals/kits are still the same.
Maybe Baker will come out hiding from the robot design frenzy week and talk
I've seen this before, but it wasn't on ITEM's site. It was on the Industrial Profile Systems website under applications. IPS was recently bought by Parker-Hannifin, the new link to IPS is: www.parker.com/industrialprofile/ The Applications section of the site is being restructured, claiming to visit back 12/19/03 (which, of course, has passed). "TechnoKART Robot" is listed on the image list, but without a link. I know this is the correct one because IPS is one of 470's sponsors and before the buy-out 45's picture was on the site.
Unread 16-01-2004, 12:57
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Post Re: Save time? Use aluminum extrusion kits!
I guess that I have a different opinion on something like this. Assuming that the robot needs to compete in 30 matches over it's life time, that's 1 hour of run time. I'd believe that the need of FIRST robots are significantly lower than industrial equipment, which is running for 8, 12 or even 24 hours spans. If this aluminum extrusion was so bad that a robot chasis could vibrate loose in a 2 minute round, I don't think that Bosch would be in business!
Tim, since you're a practicing engineer, I assume you made a quick napkin calculation about the pullout strength before you claimed that my numbers (from the manufacturer) were 'funny'. I'd like to compare some numbers with you.
Let's go ahead and take the above 20mm extrusion piece, and pretend to load in a 15 mm long fastener, and assume that the bottom lip of the extrusion that holds the T nut in is 1.5 mm tall. That looks pretty close to scale. Then we'll assume a 1700 N load on the bottom pulling it out. We'll assume the fastener (a T-nut) does NOT span to the edge of the V cutout, but rather is a 1 mm short on both ends and there's some bending going on.
Assuming the T-nut is 15 mm long, and for the sake of arguement we'll even assume the piece of extrusion is only 15 mm long too, so you just need to just bend the flaps down to pull it out, and not shear the edges like you actually do, and which would multiple the strength SIGNIFICANTLY. We'll treat the bottom flaps as two cantilevered beams, just to be safe
The transverse shear stress is 3*V/2*A
V is the shear force.
A is the area.
V = (3*1700N)
A = (15mm * 1.5mm * 2 sides)
Transverse Shear Stress = 31.875 N/mm^2
Bending stress = M*y/I
M = (1.5mm*(1700N/2 sides))
y= (.75mm)
I = (15mm * 1.5mm^3/12)
That gives me a stress of 226.66 N/mm^2
Since there's transverse shear AND bending stress, Mohr's circle comes into play here, so we'll find that the max stress from Mohr's favorite shape is:
226.66/2 + sqrt( (226.66/2)^2 + (31.875)^2 ) = 231.05 N / mm^2
With the tensile strength of the aluminum used in this extrusion being equal to 250 N / mm^2... it appears there's a factor of saftey of about 1.1. We won't go into some sort energy-distorsion or modified mohr for failure, I think my point is adequate as-is.
Since there were so many conservative factors in this entire calculation, I think that the pull out strength listed by the manufacturer is very apropriate.
I would enjoy comparing calculations that you did that say these numbers are "funny." However, I'd appreciate if you'd include the shear stress needed to rip it out of the aluminum, since that would really be required to make the case.
Bosch is a Global company that originated in Germany... not to be too nit-picky.
I agree. The numbers make this easy.
Good luck everyone!!
Matt
Last edited by Matt Adams : 16-01-2004 at 13:11. Reason: Grammer and spelling, again.
Unread 16-01-2004, 13:32
Gadget470's Avatar
A Fire Outside
As pointed out by Matt, Bosch is a German company turned International. Also, any good company will 'downgrade' their data when giving estimates data. Test Data is not the same type of data as Estimate Data.
If a company posts 'Test Data' they must post actual values recorded while testing their product. However, test data won't tell you everything about the material. ITEM's data is probably a hanging weight test (basically, hang more weight from the material until the 'flaps' fail or the material bends too far). But, there is no such thing as a perfect duplicate, and one piece may test differently the next (although probably very close).
Companies like Bosch provide estimate data which is often more useful for engineers looking to build something new. Estimate data often involves a safety factor.
The following is an example of a saftey factor in a product:
Super Rope, USA tested a specific rope type before release to the open market.
They test 20 ropes and conclude the rope can hold an average of 425 lbs before snapping.
In their product list, the rope is said to be able to hold up to 400lbs.
Look@ItGo Construction Company purchases the rope and begins to lift a cart of tools weighing 423 lbs with the rope. The rope snaps and sends the tools downward, most breaking.
Because Super Rope did not say "Our rope will hold 425 lbs" (as their test shows), but provided a downgraded value of 400, Look@ItGo has no way to claim Super Rope of being at fault for the broken tools caused by the failing rope.
While most companies will give their own safety factors, it is also important for those who are using the products to gather their own safety factors. In the above incident, if Look@ItGo was smart, they would have purchased a rope rated at 450 or 500 lbs and could trust that it would not break at a 423 lb load.
In conclusion, Bosch's data may say that it is less rigid than ITEM's, but in fact it could be better.
Remember, as Mark Twain said:
There are lies, there are 'darned' lies, and then there are statistics.
Unread 20-01-2004, 14:40
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
The BoschResxroth website lists actual test data from an independent testing firm. (thats what their website says)
Does anyone know about the interoperability of these systems? Can any system (80/20, Bosch, Item) with the same slot width use the same bolts, T-bolts, etc. I know i can sift through their documents and compare dimensions but I'd like to hear from someone who has tried.
Unread 25-01-2004, 19:10
Anne Shade Anne Shade is offline
Maryland Regional Director
AKA: Formely Anne Bergeron
no team (FIRST Chesapeake)
Anne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond repute
Send a message via AIM to Anne Shade
Question for those who use the ITEM extruded. Which connectors do you use to connect 2 pieces perpendicular to each other. We ordered the professional kit and none of those connectors seem to work very well for connecting the corners of the frame together. Just thought I would ask. Maybe you all have a picture of the connections? Thanks.
Anne Shade
Past Teams: 132, 408, 608, 832, 1002, and 2377
Unread 26-01-2004, 12:50
Loren 930's Avatar
#0930 (M-Cubed)
Hi Anne,
The two fasteners that came with the Pro Kit are 1. Standard Fastener and 2. the Automatic Fastener. The Standard Fastener is what is primarily used to make the corner connections you ask about. The fastener is comprised of two pieces, the bolt and the pressure plate. Prepare the extrusion to make the connection by tapping the core bore (the hole in the center) to M5 x .8 (standard M5 threads) about 8-10mm deep. Then drill a clearance hole thru the other piece of extrusion - we used a 4mm drill but a 3/16" will work also - the hole is only there do you have access to the bolt head of the fastener. The clearance hole you drill will be 10mm from the end when making corner connections. Drill the hole completely thru. Now assemble the fastener by putting the bolt thru the pressure plate, making sure the flat side of the plate is facing the bolt head. Now thread the fastener assembly into the tapped hole, just finger tight and then slip the pressure plate down the slot of the other extrusion piece. As you slide down the slot, look thru the clearance hole you drilled - you will see the bolt head come into view. Once you have aligned the edges of the two extrusions so they are square and flush, you can put your allen wrench thru the clearance hole and tighten the connection. Make sure you tighten it well - this will ensure the connection does not come loose. I can email you the PDF pages from the catalog showing how they work. I can't link them here, they are too large.
Hope this helps - good luck this year!!
Loren
engineering lead
Team 930
Mukwonago Masters of Machinery
M-Cubed
Unread 26-01-2004, 23:14
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
WE have Used Bosch in the past two years. 2002 we used 30x30 and it was very heavy but extreamly strong. 2003 out entire robot was pretty much built with 20x20 and 20x40 and we also had a linear sliding elevator on bosch.
pics are included below
pros: Flexiable chassis, strong structure, fast assembly if designed and cut right, flexible designing and quick changes.
Cons: Heavy(welded chassis can be much more stronger and lighter then bosch), high maintainance(we had to have 5 ppl with tork drivers to tighten all the nuts after every couple matches) and expensive. wow each t-nut was almost a buck each. tnuts break or bend quickly on over tightening, allignment is difficult at times.
2003
includes delrin sliders
as you can see we made many many many custom plates to hold the extrusions.
WE are planning to use Bosch again this year!
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 28-01-2004, 23:15
Jay TenBrink Jay TenBrink is offline
FRC #0494 (Martians)
Jay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond repute
Smile Re: Save time? Use aluminum extrusion kits!
We use an extruded product from AMC Quick Connect in Rochester Hills, Mi. their smallest section is 25.4 mm square. They use 6063-T6, which is a heat treated aircraft aluminum. They have a wide assortment of fittings and have given us excellent service. We are very satisfied with the ease of use and performance of this material and are sticking with this brand.
Our Martian robot had over 100 matches on it last year and held up extremely well. We did have to retorque fasteners from time to time. I would recommend that anyone with a bolted together frame to check and retorque the joints. A torque wrench might also be handy.
Unread 01-02-2004, 21:57
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
i saw that last year i wanted to use it this year. i spent 2 months looking for it and didnt find squat sence i didnt know the name. by now we've settle for a lot less pretty material. and too bad i wont be here next year.
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
How long should production time be??? archiver 1999 4 23-06-2002 23:16
Definition of aluminum extrusion...? kangarue23 Technical Discussion 4 25-01-2002 16:53
precision grade aluminum extrusion - item MB Kit Loren 930 Technical Discussion 2 11-01-2002 21:42
