Go to Post We've been thinking about just declaring our smallest kid on our BOM and making her part of the robot. - Qbot2640 [more]
Unread 24-01-2004, 21:29
pressurex1 pressurex1 is offline
pressurex1 is an unknown quantity at this point
Send a message via AIM to pressurex1
Can't Compile the Default Code
For some reason we can't seem to compile the default code. We got the default project loaded. We have the "Select Language Tool Suite" set to "Microchip C18 Tool Suite".
We checked that the mpasmwin.exe is pointing to the right path. We checked that the mplink.exe is pointing to the right path. And we checked that the mcc18.exe is pointing to the right path.
For the "Build Options" General tab we have the "Include" path pointing to the header file default path. For the "Build Options" General tab we have the Library path pointing to the library file default path.
We have selected the correct device (ie PIC18F8520).
Yet, when we hit "Build All" ... nothing happens. The Window button on the Tool bar says that the Output window is open... but we don't see an output window... or the output in the output window. As such, we cannot run the MPLAB SIM....
Unread 25-01-2004, 09:23
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: Can't Compile the Default Code
this sounds like windows cannot find a dll display file. you should probably reinstall the ide. but first completely uninstall the current ide.
i have found that version 6.32 would not install and run on one of my computers. however, 6.40 installs on all.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 25-01-2004, 09:37
Brian M. Brian M. is offline
CGA Team USA-Also On FRV Team 30
FRC #0500 (CGA Team USA)
Brian M. is on a distinguished road
The project files seem to save the location of the windows that are open in them. If you are running a smaller screen resolution than the computer that created the project file, could it be that the output window is starting below your viewable area? It's possible that you have to scroll down to see it (especially if the window menu says it's open).
Unread 25-01-2004, 09:42
Melissa Nute's Avatar
Melissa Nute Melissa Nute is offline
I like my hammer...
Melissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond repute
Send a message via AIM to Melissa Nute
I know my team had a problem with that at first, if you IM droids2000 or dhoward935 I am sure that either one of them will be glad to tell you how they fixed that.
Unread 25-01-2004, 20:26
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Hey, don't know if you've solved your problem yet, but...
Have you checked if you're exceeding the 64 character limit on the path/file name? You probably need to move your main working directory to the base of the file system. You can get all kinds of wierd errors if that limit is exceeded.
default code and the actual robot tml240 Programming 15 24-01-2004 11:31
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
2003 PBasic default code from Innovation First ttedrow Programming 0 06-01-2003 11:18
default code archiver 2001 2 23-06-2002 22:53
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
