Go to Post Sorry [the easy button] does not exist in robotics :D - Arkorobotics [more]
  #31   Spotlight this post!
Unread 25-01-2004, 22:13
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: Official Beacon Tracking Code Posted
Originally Posted by SilverStar
Can you add this to the repository?
http://nrg.chaosnet.org/repository - You'll need to register
Thanks, but I'd rather not have the beacon/tracking/navigation code posted elsewhere because it makes it even harder for me (and others) to support folks using the code.
-Kevin
Kevin Watson
http://kevin.org
  #32   Spotlight this post!
Unread 26-01-2004, 00:15
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
also, it's best to have the official code only posted certain places, as updates (if necessary) would be painful with multiple locations.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
  #33   Spotlight this post!
Unread 26-01-2004, 10:40
cbolin's Avatar
cbolin cbolin is offline
Programming & Electrical
FRC #0342 (Burning Magnetos)
cbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to behold
Hi,
We began experimenting with the IR sensors. We're waiting on our mechanics to get the robot assembled so we can wire it and begin to tweak the code.
The beacon works well...looks cool through a digital camera set to night vision. We are using an IR sensor to drive an LED. Tapping off signal between 33 ohm resistor and LED cathode and sending to oscilloscope.
We are curious about the IR sensitivity. About 12 feet from beacon we realize how sensitive the IR sensors are in terms of orientation (azimuth and elevation). We placed a tube around the sensor to improve detection. Turning lighting off in room seems to improve signal detection...however, this may simply be allowing us to see the waveform a little better.
Has anyone experimented with improving detection range? Other than optics of some sort, there is no way to amplify the signal inside the IR sensor since an ON/OFF signal is produced.
Regards,
ChuckB
  #34   Spotlight this post!
Unread 26-01-2004, 13:53
Squall Squall is offline
Squall is an unknown quantity at this point
I'm currently studying the program, but i just can't get how the robot follows the signal, does the motors get activated based on the pwm that the program send to the servos that have the sensors ?
The way i get it, i think it would be like this
If the sensor pwm is 100 the motors would be activated to make a left turn with the robot, is that corrent ?!
Thanks for your help
  #35   Spotlight this post!
Unread 27-01-2004, 02:30
rosebud rosebud is offline
#0115 (MVRT)
rosebud is on a distinguished road
i found out what was wrong. before i was unable to download some of the code posted and a project i was building. if any of you have trouble downloading projects between 12,000 and 18,000 bytes, and you get an error.mcp file, or the frc doesnt leave the program state, it probably is because you are running a version of ifi loader before 1.06. apparently, the previous versions cant handle medium sized files. anyways, thanks for people's help!
becca
  #36   Spotlight this post!
Unread 28-01-2004, 12:19
tml240's Avatar
tml240 tml240 is offline
bahh
tml240 is on a distinguished road
so we use beacon on EduRobot and Tracker Code on the FRC robot to see if it works???
OHL 2004- ultimate NHL 2004 MOD
  #37   Spotlight this post!
Unread 28-01-2004, 12:37
roknjohn roknjohn is offline
roknjohn is an unknown quantity at this point
Kevin,
On your website, you mention that there are two versions of receiver.c.
As there are two different versions of receiver.c, make sure that your sensors are attached according to the instructions at the top of receiver.c.
WHERE are the two versions, WHAT are the differences, and - uh- WHY?
I was using a solderless breadboard to build and test the beacon and sensors before committing to a design. Using the EDU, I was going to marry the beacon driver and the receiver code into one program to get a better understanding of how this stuff works. (i.e. one program to both flash the beacons and detect it with a sensor) Unfortunately, my first attempt at that resulted in a flashing red program state LED on the EDU. I will work on it again tonight. Are there any considerations/conflicts when including receiver.c in the beacon code?
  #38   Spotlight this post!
Unread 28-01-2004, 13:21
FRC #2429
Originally Posted by roknjohn
Kevin,
The version in tracker.zip is newer that the version used to build the kick-off demonstration code. The differences can be gleaned through examination of the FAQ and the file headers.
-Kevin
Kevin Watson
http://kevin.org
  #39   Spotlight this post!
Unread 28-01-2004, 21:56
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
I have noticed that the diagram that FIRST has posted on the photo sensor is wrong if you go by the picture. If you follow were pin 1 goes it is correct but looking how the sensor ir positioned on diagram pin 1 and 3 are swapped. We caught this by looking at the datasheet from http://www.kevin.org/frc/TSOP34840.pdf
I hope this will help any other teams that might be having some small problems with the IR sensors.
Matthew
Ubergeeks
  #40   Spotlight this post!
Unread 28-01-2004, 22:57
FRC #2429
Matthew
Ubergeeks
Holy cow! I just found the document and it is backwards. I wonder how many teams have used this document. Matthew, as this is your find, you should start a new thread with this information.
-Kevin
Kevin Watson
http://kevin.org
  #41   Spotlight this post!
Unread 18-02-2004, 19:31
arnob1 arnob1 is offline
#1155 (SciBorgs)
arnob1 is an unknown quantity at this point
I was wondering, once the Turn_To_Target state switches to the Drive_To_Target state, what is it supposed to do since Drive_To_Target is blank? Does that code have to be implemented by ourselves?
--alam
  #42   Spotlight this post!
Unread 18-02-2004, 21:04
Computer Guy
AKA: Dav
		case DRIVE_TO_TARGET:
		case PASSED_TARGET:
the way the "switch" and "case" statements work, the code for PASSED_TARGET is actually executed for both the DRIVE_TO_TARGET state and the PASSED_TARGET state. you see how most "case" statements have a "break" statement at the end? that is to keep the code from the "case"s below from executing - the break statement makes the execution jump to the end of the current block, in this case the "switch". There's no "break" after DRIVE_TO_TARGET, so it just keeps on executing downwards, and thus it's just a shortcut so that both states have the same code.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
