Go to Post 4 is kind of like 5 - Jaine Perotti [more]
Unread 23-01-2004, 16:56
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: Average Feet per Second
Originally Posted by Tyler Olds
Your bot 2 years ago (2002) went 13 FPS?????? I seem to recall it goign about the same speed as us which was about 6 FPS
Maybe you're thinking of the midlevel gear we ran at MMR, which was around 6 or 7 FPS. I was referring to the "overdrive" gear, which we didn't use until late in the season. It was theoretically 13 FPS. In practice it was less than that, as we found when we clocked it in the 10-11 FPS range in some testing last summer. It was quite a bit more than 6, for sure. Are you sure you have your numbers right?
Jeff Waegelin
Unread 23-01-2004, 17:10
Atman's Avatar
Atman Atman is offline
"Bring the HAMMER" Go 364
AKA: Team Godfather
#0364 (Team Fusion)
Team Role: Driver
Atman has a spectacular aura aboutAtman has a spectacular aura about
Send a message via AIM to Atman
This year we should be around 11fps in high and 3fps in low.
Unread 23-01-2004, 18:52
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
hopefully about 13 or 14 in high, 7 to 8 in low
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 23-01-2004, 20:14
Matt Reiland's Avatar
'The' drive behind the drive
Lets see Output of the Gearbox last year at 1600 RPM Max, reduced 3:1 into a 5" Pulley with treads gives us in the neighborhood of 8368 Inches/Min = 11.6 ft/sec in high (Just under 3 in low) and there were only a few robots that could stay with us in real life speed.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 25-01-2004, 19:36
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
the drills work out pretty well,
last year we had 160 (inches or foot !?) pounds of torque on 494's dyno with 6-8 fps.
in high we had 10 fps with an untested torque in high because we broke it's 1/4 inch steel keyway with the amount of torque we put on it in low speeed
sorry guys on 494!
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 25-01-2004, 21:42
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
SigmaC@T runs two speeds, with high being around 10-14 fps and low being around 2-4 fps. [Drill and Atwoods]
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 25-01-2004, 22:21
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
116's gearbox output is theoretically 627 rpm in high and 179 rpm in low. With the 12" wheels, geared down ~1:3.33, gives you 9.85 ft/s in high and ~2.82 ft/s in low. We are unsure if this is the ratio we are going to use, but the one we do use will be somewhat close to it.
See you in DC!
Unread 25-01-2004, 23:07
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
if your looking at the free speeds if the moters, the actual FPS will be MUCH lower. Last year we calculated our robot to run about 60 fps. in all reality it wa about 15. ( i might add it was REALLY ineffecient)
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 26-01-2004, 00:03
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
adding a load due to the motors, such as being used to drive the rest of the bot around, will slow the motors down, and quite a bit too. That's just due to the fact that there is mass that the motor has to repel, which takes away from the net force that is exerted from the motor. Acceleration thus is affected, which affects the whole speed of the robot, thus slowing the whole robot down.
Unread 26-01-2004, 14:22
Generator of Entropy
FRC #2973 (The Mad Rockers)
Maybe those lost 2-3 fps were spent compensating for driving your casters backwards
(I'm just teasing Jeff - nothing like a good technical debate).
Unread 26-01-2004, 21:03
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
For the Technokats this year, we tested our gearbox for the "Software Bot"(new this year) using 4 CIMs(all we could find in preseason) using a new, reduced gearbox and got about 16 fps in high and 10 fps in low.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Science jokes..... Adam Y. Chit-Chat 20 10-12-2004 11:55
Mad Dash for the Controls? Madison Rules/Strategy 70 03-02-2003 22:50
Crazy Idea, looking for comments archiver 1999 74 23-06-2002 22:56
Scoring and Defense. archiver 1999 10 23-06-2002 22:44
Seeding Calculations archiver 2000 50 23-06-2002 21:57
