Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread 25-01-2004, 19:51
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
White Paper Discuss: Dual-motor, dual-speed gearbox
Thread created automatically to discuss a document in the White Papers.
Dual-motor, dual-speed gearbox by dlavery
Unread 25-01-2004, 19:57
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: White Paper Discuss: Dual-motor, dual-speed gearbox
I've never responded to a white paper before but..
Ok, Wetzel gave me this link to this particular white paper and we started investigating this design as a possibility on this years robot for my team.
We ran into a bunch of design inconsistencies while planning the fabrication on this.
Some we solved by trial and error, but I just wanted to let you all know that there are problems with this design.
For one, the shaft location holes are in different places on the Y axis of the part and they don't line up when put together.
But, we solved that problem but still want to verify the correct gear for the bosch output shaft.
Is it supposed to be a 55 or 56 tooth gear?
If wetzel or anyone from Team 116 can answer these questions, please reply here.
Thanks.
BTW, I am not the one who found the inconsistancies, I am just relaying the word and trying to find solutions for my team's mechanical team.
Unread 25-01-2004, 22:55
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
The correct gear for the bosch output shaft is a 55 tooth gear.
I do not see the inconsistency with the shaft location holes that you mention. I do not believe that there is any inconsistency. BTW, this design has worked well for us in the past, so it should not have any major problems, there just might be some improvements to the design.
See you in DC!
Unread 26-01-2004, 00:00
Well, like I stated before, I m only relaying info from another team member, so I can only guess what is wrong or right.
Thanks for the confirmation on the gear size though..
If I find out the details for the supposed inconsistencies, I will PM you and try to work them out if that is alright.
Thanks for the help, and I will be getting back to you as soon as I can!
Unread 26-01-2004, 04:22
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
The "55-tooth question" has already been answered in two other threads (here and here). Please search before you post.
Please make sure that you have the correct URL. The correct link to the white paper is http://www.team116.org/2004/Transmis...riptionV6a.zip. Other development versions are out there, so make sure you are linking correctly.
As noted in the original white paper description, this design is intentionally an "unfinished work." It is intended to provide a basic shifting solution for those teams that want to take on that challenge, but may not have very sophisticated manufacturing capabilities or experienced machinists. If you have greater capabilities, there are a LOT of improvements that can be made to this basic design (ranging from significantly lightening the gears to reducing the face widths to using multiple pitch values for the cascading gears to minimizing the plate widths to ...). We KNOW there is a lot of room for improvement - it is SUPPOSED to be that way. The intent is that teams will improve upon it and post their improvements and thereby increase the overall knowledge/experience of the whole FIRST community, while maintaining the design as one that can be built with minimal manufacturing capabilities. So far, we know that at least 12 other teams have built this design (and there may be several more we cannot confirm). But so far, none of them has "gone public" with any modifications/upgrades they may have made. We are waiting to see who has taken the idea to the "next step."
-dave
Unread 26-01-2004, 11:07
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Originally Posted by Elgin Clock
... For one, the shaft location holes are in different places on the Y axis of the part and they don't line up when put together.
Is it supposed to be a 55 or 56 tooth gear?...
You are correct ... as I also noted in this post, the veritcal dimension for the hole in the "motor side" plate is .734 (which is correct) while the dimension for the "same" hole in the other plate is .810.
Also, I chose to use the 56 tooth gear and adjust the center distance to maintain proper mesh at PD. However as Dave has mentioned a couple of times, the 55 tooth gear is correct and can be ordered from PIC by substituting a '55' for the '56' in their part number.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 27-01-2004, 03:19
dlavery's Avatar
Curmudgeon
See response in this thread.
-dave
Unread 05-04-2004, 18:14
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Where can I find the "0.7 module, 20° pressure angle, 1/2” face width, 55 tooth steel gear." I cannot find it on the PIC Designs site (listed supplier), MSC, or Small Parts.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 05-04-2004, 19:24
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
Please read the thread. This gear has already been talked about many times.
See you in DC!
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox CD47-Bot Extra Discussion 35 23-01-2004 20:16
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
