Go to Post Students can learn to drive on whatever they give us. Ramps, carpet, grating, HDPE, lexan, diamond plate, regolith, other robots the driver station wall, referees, stairs, Dean, the bar, goals, the scorer's table, you name it, I've watched robots somehow manage to drive on it - Peter Matteson [more]
View Poll Results: What do you want to do more.
Just knock the 10 pt. ball out of play 47 77.05%
Bring it into play 14 22.95%
Voters: 61. You may not vote on this poll
Unread 25-01-2004, 20:36
Ben Mitchell Ben Mitchell is offline
Ben Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond repute
Re: 10 pt. ball into/out of play
Originally Posted by tkwetzel
"Add in a 2x multiplier, and it's worth 4 times as much"
It would still only be worth twice as much, because the 2x would double the 5 pointer as well. So if you put a 5 point ball in that goal instead of a 10 pointer and still capped it, it would be worth 10 points instead of 20.
If you put a ten point ball in a goal and cap it, it's worth twenty
20/5 = 4
At that point, it is worth four times a normal, uncapped ball.
Benjamin Mitchell
Vex Robotics Competition team advisor (4 high school teams)
Unread 25-01-2004, 21:59
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
"If you put a ten point ball in a goal and cap it, it's worth twenty
20/5 = 4
At that point, it is worth four times a normal, uncapped ball."
The game is not equal at this point, and the 10 point ball might make a difference. But when you strategically look at this, you should assume the same events happen, except that you put a 10 point all in the goal instead of a 5 point ball. So if you cap it or not, the 10 point ball is twice the point vvalue of the 5 point ball.
See you in DC!
Unread 25-01-2004, 23:40
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
I see very little reson to push the ball out of play unless speed is absolutely critical. Otherwise, it's like another ball only worth more points. Granted it's not worth anything to you if you miss and could hurt you if the other team gets a hold of it, but that's why you go to the gym and practice making swish shots...that shoot up past the mental barrier of where the wall would be...before the regional . Human player this year will be almost as critical as driver this year imho, if not more so
Unread 26-01-2004, 07:31
but thats the thing, the ten point ball is not like any other ball
the 5 point balls will either be on the floor, or falling in mass from the overhead bin
the ten point ball is sitting there on that tee, several inches outside the playfield
any mechanism you design to collect the 5 points balls off the floor will be useless for getting the 10 point ball off that tee and onto the playfield
so you have to design a special subsystem JUST to get that ONE ball
its not worth it - its not worth the design build test debug and its really not worth the extra time in auton mode, when you could be going after something really valuable, like the 2X ball, or your moble goal
its REALLY not worth it because a mechanism that tries to capture it instead of simply knocking it off will be more complicated and therefor more likely to fail - and if you fail to knock it off the tee you have lost 45 seconds of collection time.
in fact, if a 10 point ball is on the floor during driver mode time, it would be a mistake to go after it while there are 5 point balls on the floor
when you sweep through a field of several balls with whatever collection mechanism you have design, you will get some and some will scatter
to chase one ten point ball around, while there are several 5 point balls right infront of you, by the time you get that 10 point ball you could of had several of the other ones.
Best strategy? forget about the 10 point ball- knock it off the tee to trigger the drop, then pretend it doesnt exist anymore.
Unread 26-01-2004, 08:38
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by KenWittlief
this is a good example of how you can spend a lot of time money and resources trying to make a very small improvement in your score - its not worth it
I agree, it's a lot of work to keep track of it and even if you do manage to get it to your human player, they still have to make it into the goal, which isn't a garranteed thing. So, my opinion is, get it out of play.
Unread 28-01-2004, 09:55
20/5 = 4
Let's go over it again.
A normal, uncapped ball is worth 5 points
A 10 point ball, capped, is worth 20 points
20 divided by 5 equals 4. thus, a capped, 10 point ball, is 4 times the worth of a normal, uncapped ball.
What does this mean? It means that if you gather two of these 10 point balls, and cap the goal, you have the equivalent of 8 normal balls in an uncapped goal.
So, if you are going up against a couple of bulldozers that will quickly sweep the field before you can get a majority of balls, this route will give you the point advantage.
And rather than knock them out of play, why not utilize them?
Benjamin Mitchell
Unread 28-01-2004, 10:30
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
"20 divided by 5 equals 4. thus, a capped, 10 point ball, is 4 times the worth of a normal, uncapped ball."
I do agree that your math is correct, but irrelevent to this strategy.
When you talk about strategy of what balls to get, you should leave everything else equal. IE: capped or uncapped goals. Because if you talk about capping a goal with 10 point balls verses not capping a goal with 5 point balls, then you have an extra capability with capping, that you would be able to do with either the 10 or 5 point balls, so why wouldn't you cap the 5 point goal. The strategy just about what balls to get should not concern if the goals are capped or not.
See you in DC!
Unread 28-01-2004, 10:38
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I think you are greatly overanalyzing.
A 10 point ball, is worth 2x 5 point balls.
It's pretty simple! -- 1 yellow ball = 2 purple balls
(See Ben, I can do arithmatic too!)
I do not think they will play a MAJOR factor in the way this game is played. They are only worth 2 normal balls. In 2000, Black balls were key, but they were worth FIVE normal balls (and 1/2 a hang!).
This year's "bonus balls" just don't seem like enough of a bonus to worry about. Obviously, we'll try to get them, but I'm not going to plan a strategy around them like people did in 2000.
This means, yes, I don't care if they get knocked out of bounds.
So... why just knock them out of bounds?
Because it is:
1. Easier
2. Faster
3. My robot has more important things to do during Auto-mode.
*shrug*
$.02
John
Unread 28-01-2004, 14:17
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Lightbulb The game would be a lot different if...
Actually, I'm really glad that FIRST made this "mistake" in not making the 10 point ball worth more points. I think that the strategy would have IMMENSELY different had the 10 point ball really been worth 20 or 25 points.
This would have made designing a mechanism to get the 10 point balls significantly more worthwhile.
I think something that people tend to forget too is that you need to SCORE these 10 point balls. Having a strategy based around these objects which need to be shot by a human player would be VERY touchy. (Although let's admit it, many human players will be shooting 90+ %)
It's definitely fun to dream, "what if...."
Unforunately, it's game time folks.
Good luck,
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
Robocup Competiton 2003 - Padua, Italy patrickrd Televised Robotics 32 14-07-2003 11:57
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
