#12
Re: test autonomous mode
best thing to do is to wire up the auton and disable switches as the post above suggested
then you will be using auton mode exactly the same as it will be used at the regionals if you kludge some special user interface switch and let your own code decide when its suppose to run auton mode you may end up like many teams last year, who thought they had auton mode working great, but it would not work with the FIRST equipment on the field. The 'competition port' switch setup is the only way to go. |
| how can you use a gyro in autonomous mode | magical hands | Programming | 3 | 02-01-2004 13:31 |
| Programming Autonomous mode | Jared Stofflett | Programming | 3 | 11-11-2003 09:32 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
| autonomous mode timer | Don | Programming | 6 | 09-02-2003 22:16 |
| autonomous mode? | bigwalt | Technical Discussion | 1 | 21-01-2003 01:14 |
