Go to Post I've never encountered a motor as forgiving as a CIM - Stall them for 20 seconds, run them hot on a short turnaround, or call them mean names in between matches and they'll just keep doing their thing. - thefro526 [more]
Unread 26-01-2004, 10:25
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Help with motor rpm/torque
This isn't Wayne C. I'm his son and it wont let me log him off. But anyways I need to know how to read the performance curve of mainly the cim motors that are at
http://www2.usfirst.org/2004comp/Specs/Chiaphua.jpg
is the max rpms 5250 or do u run them at 2500?
What are they set to run at though?
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 26-01-2004, 10:54
Re: Help with motor rpm/torque
that is confusing - they nested two graphs together
the torque is a function of speed - so at a certain speed you look at the downward sloping (to the right) line to see what torque the motor can supply at that speed.
the current (on the right in Amps) is a function of torque- that line slopes up
so, for example, at 4000 rpm the motor has about 80 inch ounces of torque. draw a vertical line from that one down to the current line and it looks like it takes about 30 amps at that speed and torque.
couple things to keep in mind - the graph is only with the motor on full throttle at 12V - so if you run it slower it wont draw more current, because the victor is holding the current back
At full power you cant have a drive train that will hold the motor at an rpm that requires more than 40 amps, or the breaker will kick off - that means if your robot is blocked you either need to be able to spin your wheels, keeping the motor rpms above 3500 RPMs, or you need to use the current sensors and shutoff the motors when they are being stalled.
oops! forgot your question: 5250 RPMs is how fast the motor will spin if you have nothing connected to the output shaft, and you run it at 12V - thats its 'no-load' speed.
edit: I colored and labled the graphs from the spec so everyone can see it better.
Name:	chiaphua curve.jpg
Unread 26-01-2004, 11:31
Ok im trying to think up a gear ratio. So im taking the direct drive and compairing it to what I want it to drive at. What I did is I took the rpms and i multiplied it by the circumfrence of our tires and then i divided by 60 to convert it to inch/minute/sec. but its coming out way to large....
What do the CIM motors normally run at(RPMs)!?
4"/12"(convert to feet)=.333... * 3.14(Pi)(circumference)=1.246666ft...
1.04666ft*5000rpm=5233.3333ft/min.../60sec = 87.222... ft/min./sec?????
This is wrong why?
