Go to Post General rule of thumb: "If it moves and it shouldn't, use duct tape. If it should move and it doesn't, use WD-40.":) - ben_0614 [more]
Unread 26-01-2004, 11:43
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Help with gear ratio
This is not wayne c. this is his son. It wont let me sign him out.
Ok im trying to think up a gear ratio. So im taking the direct drive and compairing it to what I want it to drive at. What I did is I took the rpms and i multiplied it by the circumfrence of our tires and then i divided by 60 to convert it to inch/minute/sec. but its coming out way to large....
What do the CIM motors normally run at(RPMs)!?
4"/12"(convert to feet)=.333... * 3.14(Pi)(circumference)=1.246666ft...
1.04666ft*5000rpm=5233.3333ft/min.../60sec = 87.222... ft/min./sec?????
This is wrong why?
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 26-01-2004, 11:46
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Re: Help with gear ratio
RPM/60=Rev/sec
Rev/sec*(D(in)*Pi)/360=in/s
I think you have to divide by 360 degrees
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 26-01-2004, 11:53
5000/60=83.333.
83.333"(4"*3.14)/360= 2.90inchs/s = 14.5 ft/sec
Is that rite?
Unread 26-01-2004, 11:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
well you have your unit conversion a little technically wrong. it should go like this:
1.04666 ft * 5000 rpm = 5233 ft/min
5233 ft/min * (1 min/60 sec) = 87.2222 ft/sec
Otherwise your math is correct. a 4" diameter wheel on a CIM WOULD run that fast. 5000 rpm is ridiculously fast, after all. The real point is that running something straight of the CIM means it puts out very little torque. with a 4" wheel, you could stall the motor with your pinky finger. This is why all CIM drivetrains have gear systems.
Unread 26-01-2004, 12:00
What rpms do they run at im looking at spec sheet and i understand what its saying but i dont no what to use for rpms
Unread 26-01-2004, 12:09
Electrical Engineer
Rookie Year: 1995
The free speed is valid only at no load (including no frictional losses).
Look in the white paper section for a few excellent papers on how to calculate speed.
In general, design to 1/2 of the free speed and 1/2 of the stall torque.
Mike Betts
As easy as 355/113...
Unread 26-01-2004, 12:30
REVving up for a new season
FRC #2848 (All-sparks)
i made this spreadsheet last year to help someone with their drive maybe this can help you....this is for a double reduction drive train
confuzzling gear ratio definition.. wanna clear this one up? archiver 2001 5 23-06-2002 23:13
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
