Go to Post My strongest FIRST memories, and the teams that leave the biggest impact on me, are teams that seem like they have every reason to give up, but never do. - Chris is me [more]
Unread 25-01-2004, 18:06
Guest
Posts: n/a
Exclamation NRG Code Repository
The code repository at http://nrg.chaosnet.org/repository is finished.
Anybody can view the code already posted there, but you need to register for an account at the above website to add code.
The repository works only if people add and view code fairly. If you're gonna use it, add some code too! If you have any questions post them here.
If you see any "bad" code, tell me so I can delete it.
And give some reputation to anybody whose code you use!
Unread 26-01-2004, 08:37
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: NRG Code Repository
Great job!
Just 2 suggestions so far:
1] Add a way so that when you login, you don't have to do it everytime you return (just like the "Remember Me?" checkbox on CD).
2] When you do login, just redirect the user to where they were before logging in. Or atleast redirect the page after 5 or so seconds.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 26-01-2004, 13:26
Guest
Posts: n/a
Problem (2): Fixed.
Problem (1): I'm figuring out how to do the "Remember Me" box right now.
Thanx for the help!
Unread 26-01-2004, 13:28
AKA: Eric Hansen
Originally Posted by SilverStar
Problem (2) has been fixed.
Thanx for the help!
Just store a cookie, and don't delete it when the session ends. I think that'll work anywho. I know PHP & ASP has functions to get info from a cookie.
Y!: synsoflife
Unread 26-01-2004, 13:30
Guest
Posts: n/a
Got it.
Plz give reputation to anybody whose code you use. It'll tell them that they're appreciated and will make give people incentive to add useful code.
Unread 26-01-2004, 13:45
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
you still need to replace the <base href="..."> with actual references in the links.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 26-01-2004, 13:51
Guest
Posts: n/a
I've kept the base tag AND changed all the "../uploads/" paths to absolute paths.
The rest of the links are in the same directory.
Unread 26-01-2004, 14:01
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Might I suggest a directory structure of some sort? By no means, I'm not saying I know what would be a good structure ... but certainly some directory structure might help. Perhaps you could group it by input: a directory for controlling robot features using a pot, another using limit switches, gyros, encoders, etc. Maybe a special directory for autonomous code. Maybe a directory for code to control driving, and another for other elements of the robot.
The directories would, in my mind, help people to know what to contribute to the repository. Certainly short snippets that, say, lift a robotic arm via some switch, or control a gripper via pots, would help in training people to program the robot -- if they are sufficiently well-written, and well commented. The project sounds like it has potential.
Unread 26-01-2004, 14:02
Guest
Posts: n/a
Adding folders right now...
Unread 26-01-2004, 15:40
AKA: Eric Hansen
Is it possible to move the code that was previously submitted before the changes (folders)?
Also, I don't really see the need to let the user create a new folder. What if someone just does the process over & over again, flooding the server & using up more bandwidth than needed?
Y!: synsoflife
Unread 26-01-2004, 15:41
Guest
Posts: n/a
* Disabling new folder method (except for admins)
* Adding move feature (you can move your own code, and admins can move any code)
Standby...
Unread 26-01-2004, 15:43
AKA: Eric Hansen
Standby...
Ok. Great job so far though mate!
I hope this pans out for the best.
Y!: synsoflife
Unread 26-01-2004, 15:48
Guest
Posts: n/a
echos asked about posting rights.
To make it clear:
To get posting rights, you must register for an account at nrg.chaosnet.org. Make sure you put your team number on the register page.
Unread 26-01-2004, 15:56
echos's Avatar
echos echos is offline
Jack of all trades
#1125
echos will become famous soon enough
Send a message via ICQ to echos Send a message via AIM to echos Send a message via MSN to echos Send a message via Yahoo to echos
Could you make it highlight the syntax of php files?
here is the function
http://us3.php.net/manual/en/functio...light-file.php
Entity Hosting Staff
http://www.entityhosting.com/
Unread 26-01-2004, 15:59
Guest
Posts: n/a
A problem with the highlighting:
When you download the code, it's supposed to give it to you in "pure text" so that you can simply save it. So, I'll add another option - "View with Highlighting" - good idea!
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
