Go to Post Why not go the safer route? Use the robots to play Magic the Gathering. - kamocat [more]
  #31   Spotlight this post!
Unread 26-01-2004, 18:10
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: NRG Code Repository
Originally Posted by Astronouth7303
(Sorry, I'm looking at MPLAB, I don't have MSVC++ on this machine )
MPLAB does Proc. Directives blue, and I've seen them purple, too.
Keywords are bold.
Constants are a slightly lighter green then the comments.
Symbols are gray ({} > < = ; etc.)
Strings are blue BUT NOT BOLD!
The colors (and purposes) are below:
  • 000000 Default
    2121B5 Strings, Hex
    2121CE Keywards, Processor directives
    218C21 Numbers
    296B52 Comments
    848484 Symbols
    FF0000 Errors
    FFFFFF Background
I'd post the image, but I can't attach (or can't find the button)
Would it be possible (sometime in the future) to put the coloring specifics in the User CP?
I think having a light color on a light background is bad though. I've had numerous accounts of adding a double '{' thinking I didn't have the first one in, because of the very small contrast in colors.
But thanks for the list of the color/values. For attatchments, there's a button called "Manage Attatchments". Click that, and that'll let you upload stuff
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
  #32   Spotlight this post!
Unread 26-01-2004, 18:16
Guest
Posts: n/a
My decision:
I'll go with everything in the post quoted above.
  #33   Spotlight this post!
Unread 26-01-2004, 18:33
Guest
Posts: n/a
Want to see the current source of the highlighter?
Go here: http://nrg.chaosnet.org/source/repository/download.php
  #34   Spotlight this post!
Unread 26-01-2004, 18:38
AKA: Eric Hansen
That's really cool. Thanks for showing the source for it. Did you use any PHP functions for showing the code? (I know there's highlight_code(...) & show_source(...)....don't quite understand how they work though)
Y!: synsoflife
  #35   Spotlight this post!
Unread 26-01-2004, 18:40
Guest
Posts: n/a
I use a buffer to hold all the source so that I can format it into a table with line numbers. You're right, I use show_source and highlight_file (not _code)
  #36   Spotlight this post!
Unread 26-01-2004, 18:41
AKA: Eric Hansen
Cool. Sorry about that, I forgot weither it was highlight_file or highlight_code
Y!: synsoflife
  #37   Spotlight this post!
Unread 26-01-2004, 19:38
Guest
Posts: n/a
Our job now:
To get people to add code to the repository.
And, can this thread be made sticky?
  #38   Spotlight this post!
Unread 26-01-2004, 19:52
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Syntax hilighting is not quite so simple. There are special cases you have to account for, that make the code somewhat more complex. For example, if I make a comment that says:
// If the "if" statement's condition below is true, it should run the "auto-vivify-functifier"
I wouldn't expect 'if' to be highlighted another color, nor would I expect the text in quotation marks to be highlighted another color. Also, you have to watch out for "This string keeps on \" going \", even though I just had two quotation marks, I'm still not finished." There are many other conditions you have to watch out for, too. Sure, not all these cases might come up, ... and really, someone can just copy the coad into their favorite C editor anyway, ... but I'd look for an already done solution (why reinvent the wheel? unless, of course, this is for your edification, in which case you might want to think about more of the special cases yourself).
For an example of some conditions you didn't catch, look at the PID code. EDIT: especially, looking over it again, in the Trig lookup table, the "extra" highlighted parts of the comment can get annoying, and potentially mess someone up.
  #39   Spotlight this post!
Unread 26-01-2004, 20:27
Guest
Posts: n/a
The reason I did not use an already made module is because I don't have permissions on the chaosnet server (our host) to install stuff. Since people can see the "special cases" in their own editor (like you said), I'm not gonna spend much more time working on the highlighter. If anyone wants to, they can post it in "Website (Perl/PHP)" folder.
  #40   Spotlight this post!
Unread 26-01-2004, 20:36
Guest
Posts: n/a
Each entry can now be rated on 1 to 5 scale.
  #41   Spotlight this post!
Unread 26-01-2004, 20:57
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
cool beans.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
  #42   Spotlight this post!
Unread 26-01-2004, 21:05
Computer Guy
AKA: Dav
btw, SilverStar, do you have AIM (preferably) or MSN?
  #43   Spotlight this post!
Unread 26-01-2004, 21:07
Computer Guy
AKA: Dav
pm, then? or just message me - deltacoder on AIM, mobile@vectorray.com on MSN
  #44   Spotlight this post!
Unread 26-01-2004, 21:10
Guest
Posts: n/a
just post stuff here, i'll read it.
  #45   Spotlight this post!
Unread 26-01-2004, 21:17
Guest
Posts: n/a
Originally Posted by deltacoder1020
btw - would it be possible to add both a comments system and a file update system to the repository?
Working on comments system, should be simple.
File update system - you can always edit your code. But I'll work on an version managemtent system (will take time).
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
