Go to Post Definitely read through ALL the documentation, and if you still have questions, ask. - Joe Ross [more]
Unread 18-01-2004, 20:48
Wacko324's Avatar
Wacko324 Wacko324 is offline
AKA: Matt Mericle AKA "Miracle Matt"
#1495 (Avon Grove Robotics)
Team Role: Driver
Wacko324 is on a distinguished road
Send a message via AIM to Wacko324
Plez help me
I am on a rookie team and no one is very good at electrical and programing. So I got stuck with them. Can anyone tell me how I hook a switch board up to one of the ports of the OI?
Unread 18-01-2004, 21:01
Umm Errr...
Re: Plez help me
Sure, but please elaborate on what you mean by "switchboard".
1139 Alumni
Unread 18-01-2004, 21:11
Re: Plez help me
I dont know if you are aware of this, but there is complete documentation on the OI and the RC on the innovationFirst website - I snarfed this text from the operator interface reference guide:
___________________
Digital Inputs (see pinouts on pages 7-10)
Each port provides four unique digital inputs. PORT 2 provides access to the same digital inputs as
PORT 3, allowing access to 8 digital inputs from PORT 2. PORT 4 provides access to the same digital
inputs as PORT 1, allowing access to 8 digital inputs from PORT 4. To utilize these inputs, wire buttons
or switches between the desired digital input signal pin and any ground pin. A digital input senses a
connection to ground to become active. Do not connect switches or digital inputs to 5V. Do not use
lighted switches.
______________________
so basically is you want to add more switches (switchbox) to the OI - you connec them between the digital input pins and the ground pin - see the table in the reference guide to see which pins correspond to which variable bits in the default code.
the full documenation is here:
http://www.innovationfirst.com/FIRST...umentation.htm
- Ken W - Sparkie engineer on team 578
Unread 19-01-2004, 10:14
Wacko324's Avatar
Team Role: Driver
Re: Plez help me
I didn't know they had documentation of the OI. That really helps, thanks.
Unread 23-01-2004, 02:31
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Plez help me
Do not forget to use the disable dipswith on the bottom of the OI if you need more digital switches on port 2 or port 4 (the pins that say "same as" some other switches). Its use is detailed on the page 17 of the OI Guide
Robot Inspector
Unread 24-01-2004, 00:04
Wacko324's Avatar
Team Role: Driver
Re: Plez help me
Don't worry I finished reading up on the OI and Robot Controller the past week. So I got those down now. So I am alright with the OI. Sadly I am still shaky on the programing.
P.S. I am doing a little rewiring of the electric system you helped us start, so it can fit in a smaller space.
Unread 26-01-2004, 08:52
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Plez help me
Well, post to the programming forum here. There are lots of people willing to help.
FIRST should supply better documentation on the programming of the RC. I'm on a rookie team, but I know C/C++ (and Java and Visual Basic ) so I managed to figure it out. But for someone with no programming experience, I can see how it would be hard.
Unread 26-01-2004, 13:48
The Lucas's Avatar
Re: Plez help me
I didn't notice until a second ago, but you are on team 1495 (Avon Grove) the team I am mentoring (I guess I was a little tired when I posted, I skiied really hard that day because it was my birthday). Is this Matt? How did the rewiring go? Don't worry about the programming right now. I'm back from my week vaction skiing Vail, Colorado and I'll be at your next meeting (as soon as it stops snowing and Avon Grove actually has school). I'll teach you all you need to know about the program then.
Robot Inspector
Unread 26-01-2004, 20:24
Wacko324's Avatar
Team Role: Driver
Re: Plez help me
Yup this is "Miracle Matt". The rewiring went really well we have all the main electrical components mounted to the board and are ready to hook everything up when we get back in school.
