Go to Post 32% of the teams in any division will be or could be in eliminations. And any one of those could be YOU. If you aren't ready, you will be eliminated. If you are ready, you greatly increase your chances of winning. - EricH [more]
Unread 24-01-2004, 18:00
Ben.V.293 Ben.V.293 is offline
Ben.V.293 will become famous soon enough
Send a message via AIM to Ben.V.293
any success with winches?
my team has been experimenting with winches from day one but have not been very lucky so far. first we tried using 2 globes driving one shaft. It should have had 150 lb/in. of torque but we could only get it 112 lb/in. at the shaft. after trying a few differant pulleys we got it to work but it was a little slower than we would have liked. then we started working with the van door motor which should have had 300 lb/in. at the shaft. we mounted the van door in a small transmission and tried it out but it stalled while trying to lift me, i weigh 140. we then tried the motor with a 2-1 reduction and it was very close to lifting me but could not do it. then finnaly we tried a 3-1 reduction and it was successfull but its a little slow. has anyone else had any success and if so could u tell me what motors your using or even better, post a picture?
thanks
Unread 24-01-2004, 18:03
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: any success with winches?
Before even attempting to make ours, the engineers and I have been doing calculations on MathCAD to see what'll work and how fast it can do it. So I'll tell you whether our numbers actually reflect the real thing when it's done.
... not that we're officially trying to hang or anything
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 24-01-2004, 19:01
President, VEX Robotics, Inc.
Do the Math
O.K., here is an example:
I will use the 2 window motors, but the math works with any motor.
Tmaxp is the torque at max useable power (power just under breaker limit)
Wmaxp is the speed at the above condition
Dw is the diameter of the winch spool
Vlift is the lift velocity
Fr is the lifting force required
For our case:
Tmaxp = 4.6N-m
Wmaxp = 46 RPM
Fr = 130 lbs
We will not be using any gear ratio, just direct drive off the window motors
Equation #1: 2*Tmaxp = Fr * Dw/2 (the 2 on the torque side is due to the 2 motors)
Equation #1: Dw = 2*2*Tmaxp/Fr
Equation #1: Dw = 0.032 meters [32mm] (remember to convert lbs to Newtons)
Equation #2: Vlift = Wmaxp * Dw/2
Equation #2: Vlift = 46RPM * (2*Pi/60)rad/s * 32mm/2
Equation #2: Vlift ~ 77.1 mm/s [3.03 inches/s]
So we have a winch that can lift 130 lbs @ 3 inches/sec.
This winch could lift 1 foot in 4 seconds or 2 feet in 8 seconds.
I hope this helps.
-Paul
Unread 24-01-2004, 19:05
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Okay, shameless plug time:
http://www.chiefdelphi.com/forums/pa...le&paperid=252
In the whitepaper I wrote:
Using the "Mechanism Design" worksheet in the "Design" workbook, one can easily plug and chug numbers for a winch design.
Simply input your motor specs at the top (get these from the "support" workbook), enter any speed reductions you are using, and what size pulley you want (in the torque radius box).
Plug in the "efficiency factor" and you're ready to go.
Try out different load characteristics to see how fast you will winch up, and what kind of current your motors will be drawing.
I found it useful, does anyone else?
John
Unread 24-01-2004, 19:16
briholton's Avatar
briholton briholton is offline
AKA: brian holton
#0752 (Gods of Fury)
briholton is on a distinguished road
Originally Posted by Ben.V.293
first we tried using 2 globes driving one shaft. It should have had 150 lb/in. of torque but we could only get it 112 lb/in. at the shaft. ..... then finnaly we tried a 3-1 reduction and it was successfull but its a little slow.
thanks
Hey Matt, what is the lever arm of your winch? In other words, what is the radius of the cylinder that the "rope" winds around? I'd be curious because this week I was planning on using the van door motor with winch and thought it would work well....... silly me.
thanks
Unread 24-01-2004, 20:33
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
thanks
I will tell you that the van door motor does work we used sprokets to change the power. we used a 5" cylinder this was done in 2000
We are using the 2 tyco motors. we cut our own gears but I bet you can find gears that would work
We are going up 18" per second we can pull over 200lbs
we are using a 6" cylinder with a bar to stop back drive. this is a one ticket up until we reset it.
Unread 24-01-2004, 22:06
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
18 inches per second?
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 24-01-2004, 22:22
Easily 18" per second. If they use the 2 CIM motors (I don't know what Tyco motors are) with a gear ratio of around 61:1 and a 6 inch spool, at 40 amps they could lift around 234 lbs (depending on efficiency ... I used .95^4) and go 18" per second. What this means is that they really are moving almost 2x that speed if another robot isn't hanging on them.
Sounds to me like someone is taking power from their drive wheels .......
Unread 24-01-2004, 23:00
edomus's Avatar
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
If we use the drills and cims in our drivetrain what would you recomend using for the winch?
Unread 24-01-2004, 23:07
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
why not use the drills and cims for both?
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 24-01-2004, 23:10
You could use the window motors from my post earlier. Or, you could use the van door. Instead of telling you what spool size to use, I will let you figure it out with some help.
O.K., here is the van door motor torque equation:
Torque = (-34/75)*Speed + 34
Speed (angular velocity) is in RPM and torque is in N-m. At max power your speed and torque are approximately 38RPM and 17N-m, respectively. Let's assume you want to be able to pull up yourself and another robot at max power(in case your opponent is trying to hold you down) so that is 260 lbs.
Assume no gearing, just a spool right on the Van door shaft. What diameter of spool do you need? After you figure that out, then tell me how fast you would be going at max power. Then tell me how fast you would be going if you were only lifting 130 lbs.
Equations of interest:
1. Torque = Force * Diameter/2
2. Velocity = Angular Velocity * Diameter/2
After you give it a shot, I will help.
-Paul
Unread 25-01-2004, 23:55
Jay TenBrink Jay TenBrink is offline
FRC #0494 (Martians)
Jay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond repute
Question Re: any success with winches?
we are using a 6" cylinder with a bar to stop back drive. this is a one ticket up until we reset it.[/quote]
We will use winch motors that can backdrive (Fischer Price) and will need a device to prevent backdriving as well. Has anybody come up with an elegantly simple way to accomplish this? We would like it to be a passive device, similar to the clutch in a manual window regulator mechanism.
We'd rather not have to use a cylinder/blocker device because of the weight. Has anybody had experience using an electrically actuated servo to move a latch pawl or something like that?
Unread 26-01-2004, 07:21
FRC #0061
Rookie Year: 1995
We'd rather not have to use a cylinder/blocker device because of the weight. Has anybody had experience using an electrically actuated servo to move a latch pawl or something like that?[/quote]
http://www.valleytech.k12.ma.us/robo...02%20Claw2.jpg
If you take a look at this device it is very simple to stop a motor to back drive. we use this claw to hold onto the 180lb goals and pull them around. Vey strong.
Building FIRST robots since 1995
BVT Robotics
Unread 26-01-2004, 20:43
Bacchus's Avatar
Bacchus Bacchus is offline
Uhm. Yeah. I'm "That guy"
AKA: Stephen Taylor
#0229 (GRT Alum / Division By Zero)
Bacchus is just really niceBacchus is just really niceBacchus is just really niceBacchus is just really nice
Send a message via AIM to Bacchus
My recommendation would be to use a ratchet and pawl. These parts are easily available from many gear companies including Berg(http://www.wmberg.com/catalog/catres... oup=RATCHETS), or if you're on a really tight budget you can probably get creative with a band saw and a grinder. I would be very hesitant to rely on a mere servo to disengage the pawl. However, something like a pneumatic with a very short throw would be suitable.
Unread 26-01-2004, 20:54
Umm Errr...
whats wrong with a spring loaded pawl? Just look at the hand power winches they well at home depot. As mentioned above you could easily fabricate something like his with tools as simple as a a bandsaw.
1139 Alumni
Success with Tank Treads Yan Wang Technical Discussion 17 23-01-2004 15:53
Strategy for success Sully Rules/Strategy 11 10-01-2003 18:50
When are they going to finish the FIRST EDUrobot- a primer for success website? team222badbrad Robotics Education and Curriculum 0 28-12-2002 19:10
Here Is The Key To Fundraising Success "that's The Ticket"!!! DaBruteForceGuy Fundraising 23 19-11-2002 22:12
Another post that will get 105 replies and 900+ Views... What is success??? Robby O Chit-Chat 9 03-08-2001 21:47
