Go to Post First off, let me suggest that you read the rules! There is an amazing amount of really good information in them. - dlavery [more]
Unread 26-01-2004, 21:44
Umm Errr...
Drill mounting
What is the easiest way to mount the drill motor into a plate? It doesn't have any mounting holes. Can i make a hole and press it in by that lip thing?
1139 Alumni
Unread 26-01-2004, 21:54
Matt Reiland's Avatar
'The' drive behind the drive
Re: Drill mounting
Here is a 'robust' way to hold on to it.
An aluminum ring that uses 6/32 tapped holes to hold in the motor to the plate (also a good heatsink)
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 26-01-2004, 22:50
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Drill mounting
You could hook it up to a semi thick plate with the mounts and then screw that plate into another using small screws and loctite
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 26-01-2004, 22:56
Umm Errr...
Re: Drill mounting
Alot of pictures IE:Technokat gearbox have the drill motor just magically sticking out of the side how is this done? Or are there mounting holes an i just didn't see them. Also, I can't find a spec sheet with dimensions for the drill motor, only the torque characteristics.
1139 Alumni
Unread 26-01-2004, 23:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Drill mounting
You could probably grab a pair of calipers and make your own. Anyway, the Cybersonics have an Inventor model of it. Let me know if you want it.
Unread 26-01-2004, 23:15
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Re: Drill mounting
I imagine that you could modify the existing housign for the drill motor, gear box, and transmision to accomodate just the motor. You might have to get creative with the top middle bracket to have it hold the motor in place and you might need to push in some cork to use as a spacer like we did last year and just cut off the rest of the un-needed drill motor housing.
Unread 26-01-2004, 23:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Drill mounting
They tapped the holes on the face of the drill motor.
2001-2004: Team 100
2006-Present: Team 254
Unread 27-01-2004, 00:13
K^2 K^2 is offline
AKA: Karl Kreder
#0461 (Boiler Invasion)
K^2 is an unknown quantity at this point
Re: Drill mounting
If nothing else there is an inventer file available of a complete drill motor, transmission and mounting bracket available in the virtual kit of parts. We used it in the design of are drive system and it worked superbly.
Previously team 167
~Winner of Delphi's Driving Tomorrows Technology award at Motorola Midwestern Regional
~Winner of Delphi's Driving Tomorrows Technology award at The Championship
~2nd seed Galileo Division
~Quarter finalist Nationals
Unread 27-01-2004, 00:31
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Drill mounting
However, I'd like to mention that you be careful about using the firstcadlibrary inventor files on the plastic mounting brackets. Plastic parts vary wildly, and in our instance one of the inventor parts designed by Ed Sparks had hole distances .030 different than ours.
I know that Ed prides himself in building top-notch models, so it's not because he was inaccurate, but because the distances simply aren't uniform.
Measure twice, model once, cut once.
Good luck,
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 27-01-2004, 02:14
President, VEX Robotics, Inc.
Re: Drill mounting
Attached is a drawing in PDF format that shows the part we are using this year. The side hole is made for an 8mm spirol pin. It is a standard metric pin. The pin mates to the larger counterbore on the side, which is a new feature on this year's motor. There is a smaller hole you could mate to on the side of the motor and we did that last year, but you must be very careful not to push the pin too deep. Using the counterbore will help the depth issue this year. The drawing is in metric.
-Paul
mounting of the small gear directly to the shaft of the drill Andrew Dahl Motors 0 19-01-2004 12:18
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
