Go to Post I've always responded to the cries of, "robot!" with, "person!" I always get startled looks. It's fun. - Rich Kressly [more]
Unread 27-01-2004, 19:49
David66's Avatar
David66 David66 is offline
YA TOAST!
AKA: David Butzin
FRC #0066 (The Flyers)
David66 has a spectacular aura aboutDavid66 has a spectacular aura aboutDavid66 has a spectacular aura about
Send a message via AIM to David66 Send a message via Yahoo to David66
Re: Hanging After Match
Originally Posted by ngreen
So does this say that as long as you settle up to a position above the ground in ten seconds and stay in that position (or at least be above the ground, possibly in some movement still, i.e. swinging) for at least until judging stops, 30 seconds +. You will be awarded the 50 pts.
Swinging must be ceased within the ten second time frame. And your robot can settle into nay position above the ground as long as its at least 12 inches above the carpet (this is in the rulebook)
Proud Alumni of Team 66
2005 Great Lakes Regional Champions with Team 67 (HOT) and Team 68 (Truck Town Thunder).
2005 West Michigan Regional Champions with team 107 (Holland Christian High School) and Team 93 (New Apple Corps)
2002 National Champions
Unread 27-01-2004, 21:48
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
If the robot is clearly hanging but still swinging without touching anything, it will count. The ten seconds is a general rule, more of a guideline really, that the refs will give the dust time to settle.
Wetzel
Unread 27-01-2004, 22:03
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
are you sure that it says that you need 12 inches above the floor? i don't seem to remember that...
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 27-01-2004, 22:30
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
He said 12 inches off the carpet.
The platform is 12 inches off the carpet
pretty much how I understand the rules is that you can't touch anything except the horz. bar within a time period. The time period set by FIRST is 10 seconds after the match is over.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 27-01-2004, 23:01
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
If you are having trouble with a motor unraveling, the you could design a simple locking mechanism. If you attach a small wheel to the shaft the motor drives and have that wheel have some sort of holes in the side (like spokes maybe) - then all you have to do it put a small pneumatic next to it and send it out into the wheel when you want to lock it in place. I'm sure there are countless other ways to lock a motor. My point is really just that you could lock it instead of worrying about the rules.
Also, if you intend on pulling yourself up high, you might want to put an extension on your tether that's near the outside bottom of the bot. Yes, they can lower the bar, but it would save you a lot of time if you could tether yourself down.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 07-02-2004, 16:51
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
I read a lot of these type post but I have one more question for everybody.
If I take the 2X ball and put it under our robot while hanging, then when the power goes out the motors start to back drive until the ball hits the ground. then the motor stop back driving when it sits on the ball.
Does this give us 50 points. we at that time would still be connected to the top bar and we would not be on the ground. the ball is part of the game and not the robot.
Building FIRST robots since 1995
BVT Robotics
Unread 07-02-2004, 17:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
To quote FIRST, "Please see the definition of HANGING and SUPPORTED, they are clear and unambiguous in this case."
But seriously, I'm pretty sure your robot would be counted as being supported by the ball beneath you.
Unread 07-02-2004, 18:21
It doesn't matter if the robot is supported by the ball. It only matters if it is not touching the carpet, platform or goals. It also must be directly SUPPORTED by the bar, which means they would no longer be HANGING if they removed the bar. Since it is unlikely that they could balance on the large ball, they would be considered directly supported.
Granted that is how the rules are written now, and if you asked FIRST they would probably tell you to stop being a lawyer
Unread 07-02-2004, 18:51
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Words mean what words mean. If your robot is sitting on the ball, then by definition it is not hanging from the bar. NO 50 point bonus.
-dave
Unread 09-02-2004, 19:41
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
this would not be considered hanging because the 2x ball is supporting the bot, not the ball...if you were to remove everything but the bar, the bot would continue to backdrive till it touched the ground...so no, it would not be supported by the bar and thus, would not get a 50 point bonus
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
hanging Gamer930 Rules/Strategy 7 17-01-2004 18:30
Thanks 968 and 294 and last match LA sanddrag Regional Competitions 5 16-04-2003 17:15
How should FIRST Replay a match Matt Reiland Rules/Strategy 4 09-03-2003 11:11
Thanks - Wild Stang - What a match!!!!!! archiver 1999 1 23-06-2002 22:15
Avg Score CMC General Forum 14 12-03-2002 07:23
