Go to Post I'm wondering just what you think the people who DID set this system up actually do for a living instead? Sheep farmers? - DonRotolo [more]
Unread 24-01-2004, 17:17
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Programming joysticks
On the new joysticks, there is a mini - milt-direction "d-pad" i guess you could call it. How do you prgram this, or can you even. I can't find it anywhere in the code
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 24-01-2004, 18:22
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Programming joysticks
It's called a "hat switch" and it'll show up as one of the analog joystick values to the robot controller. I can't remember if it appears as "Joystick Wheel" or "Joystick AUX" off the top of my head, though.
Unread 24-01-2004, 18:36
NoRemorse's Avatar
AKA: Brian Roberts
well, the count of buttons on thejoistick does not equal the count of buttons in the program. and it is the odd man out.
Unread 24-01-2004, 19:14
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
The joystick's POV hat takes the place of the "pN_wheel", where N is the number of the joystick port you're using. I can only really speak for the joystick which I have right in front of me (the other is at my house, being used to play TIE Fighter ), so YMMV. The two least significant bits of the value change too erratically to be of any use. Here's a listing of the values of the variable when the POV hat is in different positions:
Neutral: 001011xx
Up Left: 111111xx
Up: 111111xx
Up Right: 111111xx
Left: 011000xx
Right: 110010xx
Down Left: 101001xx
Down: 100101xx
Down Right: 110101xx
The x's take the place of the two least significant bits, which, as I said earlier, change randomly (at least with this single joystick).
Basically, if you can understand binary, you can take advantage of the POV hat for controlling your robot.
Hope this helps.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 27-01-2004, 18:12
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
I have two basic questions. First, can those old robot interfaces be programed for C or are they strictly the old stuff?
Second, does anyone have an old program with just the two joystick controls? All we want to do is hook up an old interface to a mock control board so we can make sure the trannys work.
(Note: Im the fabricator, the only thing i know about computers is how to break one)
Hopefully i can relay this answer to one of our more knowledgeable people. Thanks
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
Unread 27-01-2004, 20:31
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Do you mean the old robot controllers? If so, they can only do the old PBASIC stuff.
Unread 27-01-2004, 21:21
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Neutral: 001011xx
Up Left: 111111xx
Up: 111111xx
Up Right: 111111xx
Left: 011000xx
Right: 110010xx
Down Left: 101001xx
Down: 100101xx
our values for the joystick concur for the first 6 bits as well. (darn shame there is basically no difference between UL, U, and UR)
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 28-01-2004, 05:51
InnovationFirst has "Legacy Documentation" on their website. They have default code, written in PBASIC (for previous years' control systems), for both single and dual joystick driving. Here's a link to download those programs. They're listed under "PBASIC Code", but you will also need a copy of Parallax's computer program, in order to program your controller. Links are listed on that same website under "Programming Tools".
If you need any more assistance, feel free to ask.
Unread 28-01-2004, 20:53
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
So the bit masks are:
const unsigned char Hat_None = 0x2C;
const unsigned char Hat_Up = 0xFC;
const unsigned char Hat_Left = 0x60;
const unsigned char Hat_Right = 0xC0;
const unsigned char Hat_Down = 0x94;
//Unless values are off, Combos aren't OR'ed
const unsigned char Hat_Up_Left = 0xFC;
const unsigned char Hat_Up_Right = 0xFC;
const unsigned char Hat_Down_Left = 0xA4;
const unsigned char Hat_Down_Right = 0xD4;
This seems a little stupid, but that's life.
Unread 01-02-2004, 23:59
Chris Hleva Chris Hleva is offline
#0905 (Razor Burn)
Chris Hleva is an unknown quantity at this point
Send a message via Yahoo to Chris Hleva
Question Programming joysticks
I have a question, how could I add the right lines of code to make the POV hats work with the new C language this year? Amonst other things, where would I have to define them and map them to the right IO ports to work with the hex/bin input signal?
Unread 02-02-2004, 11:11
Programming User
You also have to good at bit manipulation in C!
Unread 02-02-2004, 11:15
Why not #define them, instead of taking up memory?
Unread 02-02-2004, 12:45
Computer Guy
AKA: Dav
example:
if( (p1_wheel & 0xC0) == 0xC0 )
     //hat control is pushed right
else if( (p1_wheel & 0xA4) == 0xA4 )
     //hat control is pushed down-left
et cetera
just use the bitwise AND function (&) to determine if the correct bits are set.
Unread 02-02-2004, 16:59
#0905 (Razor Burn)
Thanks, that helped a lot. I am just starting out with C so i'm still a little sketchy with it.
Unread 02-02-2004, 17:21
Computer Guy
AKA: Dav
no prob. if you want a review on the syntax of C, you could try the various guides in the whitepapers section, or the guide that I'm working on (see the thread in this forum titled "FIRST Programming Tutorial")
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
Could use some help with joysticks . . . archiver 2001 5 23-06-2002 23:36
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
pbasic programming punarhero Programming 4 21-01-2002 23:32
