Go to Post You hang for show; kick for dough. - Travis Hoffman [more]
Unread 28-01-2004, 08:54
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Really big sproket
Our team is hoping to use a 12" OD sproket, so far all the sprokets i've found only go to about 6" od. Is there a sproket out there that big? or should I just try to make a rough one on my own?
let me clarify, I need that sprocket in an inventor(6) file, sorry if i'm just blind and i can't find it on the other threads, but i'm looking
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 28-01-2004, 09:21
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Re: Really big sproket
This thread might interest you.
-Joel
Unread 28-01-2004, 09:23
Dick Linn's Avatar
no team (Synergy)
You can probably find one, but it is more likely to be for a 420 size chain or larger. Various off-road go-karts and motorcycles are likely to use this larger size. They may also be available in aluminum to keep the weight down. You can also use an intermediate shaft with more sprockets if gearing down is what you want to do.
Try Azusa Engineering. They list up to 100 tooth sprockets in #35(hthttp://www.azusaeng.com/azusaline.html). Here's a 1-piece 72 tooth aluminum sprocket for #35: http://www.mfgsupply.com/m/c/AZT5313...ml?id=gDhaXDzL
Possibly try sprocketspecialists.com They list sprockets up to 72 tooth, but you have to fish around by the make of motorcycle.
I believe one of the West Virginia teams used a very large sprocket last year to make a 4WD 4 wheel steering 'bot last year.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 28-01-2004, 15:05
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Azusa makes 11" off the shelf...
If you follow the thread about "Who Needs Large Aluminum Sprockets?", you will see that I think that Azusa is a good source.
I don't think they make #35 sprockets 12 inches in diameter, but they are close. They make 94T sprockets which have a pitch diameter of a little more than 11 inches.
Hope this helps.
Joe J.
Unread 29-01-2004, 01:43
yamo18's Avatar
yamo18 yamo18 is offline
AKA: Bryan
#1188 (Oaktown Crewz)
yamo18 is on a distinguished road
Send a message via AIM to yamo18
FirstCADLibrary Here you can find Sprockets. There is an I-Sprocket where you can make the dimensions whatever you want. Hope this helps.
Bryan
Unread 29-01-2004, 09:52
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Bryan
Keep in mind that the i-parts are only usefull if you can actaully buy (or manufacture) the part.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 30-01-2004, 08:25
Techincal assist
AKA: Brian Clegg
Bryan
Thanks, but that was the first sproket I tried, and it only goes to 60 teeth, or about a 6" od, I need some thing twice that size, so unless someone can tell me how to make custom I-sprokets, that doesn't help much. thanks though!
Unread 30-01-2004, 10:07
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
is it necessary that this sprocket have continous motion?
I am assuming that you need a sprocket of this size so as to increase your torque for picking up a large arm of some sort. As a general rule, a large arm affixed to a robot will never rotate more than, say, 300 degrees. If this is the case, you don't need an actually sprocket.
If you make a large wheel out of plywood or aluminum, it will serve the same purpose. simply wrap the chain around it and pin it in place on the wheel. because the chain is actually attached to the wheel, it cannot rotate past a certain point, but that's ok if your arm can't go that far anyways. you can usually make something like this to give you about a turn and a half of rotation, so say 540 degrees (more than enough). it also gives you the freedom to make it any size you want, and its lighter cause you can make it out of something that weighs a lot less than steel.
Unread 30-01-2004, 15:46
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Just add a line to the i-part table with the specs you want and it will be selectable when you insert i-sprocket in your assy.
Ed Sparks
MECH TECH FRC-3959
Goaltending- the next big controversy Wayne C. General Forum 69 23-01-2004 14:07
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
When you go for big balls... archiver 2001 5 24-06-2002 00:54
4 big balls on top of the goals archiver 2001 8 23-06-2002 22:27
