Go to Post If the refs are not calling something that you think should be called, you have to adjust your play style to deal with it. - Rob [more]
Unread 28-01-2004, 22:09
Umm Errr...
Question Inventor problems
Riiighht.... So how do i unconfuse inventor when it freaks out because i moved an assembly and associated files from one computer to another? At least i think that's the problem. Anyway, i moved some filez from one computer to another and now whenever i try to open any of them, I get a message "error in reading RSe streamer segment." Uhhh... How do i fix this??
1139 Alumni
Unread 28-01-2004, 22:20
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Inventor problems
Did you move the part with the assembly file too? I've never had any problems with Moving files.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 28-01-2004, 22:22
Umm Errr...
yep, all the parts are there. I know that's not the problem bc i can't even open the individual part files. Same message.
1139 Alumni
Unread 28-01-2004, 22:24
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Same Inventor Version I'm assuming?
Kevin Li
596 - Sciclones
Unread 28-01-2004, 22:25
Umm Errr...
I know they are both 5.x. I'm not sure about subversion.
-------------------------- Edit --------------------------
Grrr..... After some googling, it seems that this is the error you get when you try to open files from diff versions. I guess subversions do matter. I'm not sure i completely trust that though. If that were true then how come the files from flaces like csbliss and First Cad Library work fine for me. Are they saved in a really early version format or something?
Grrr.... Anybody have a .ipt to .step converter?
1139 Alumni
Unread 28-01-2004, 22:27
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Why not 7?
Kevin Li
596 - Sciclones
Unread 28-01-2004, 22:31
Umm Errr...
Why not 7?
Well I took ot home over the weekend, but never found time to load it. 7 will come soon.
Note: read edited post above.
1139 Alumni
Unread 29-01-2004, 12:58
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
... Anyway, i moved some filez from one computer to another and now whenever i try to open any of them, I get a message "error in reading RSe streamer segment." ...
That error message sounds like an Inventor version problem. Even within a major rev, you may have problems, such as between 5.0 and 5.3, in my experience.
Pete Kieselbach
Unread 29-01-2004, 16:48
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
We also had a similar problem....we had to make project files to transfer files between computers or the computer would get confused.
-Pat
