Go to Post This is ChiefDelphi. There are threads on everything! - LauraN [more]
Unread 29-01-2004, 02:37
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: super scooter
Unread 29-01-2004, 02:38
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: pic: super scooter
A new use for the chip motors. very creative and the price to have one of these is about $4500 less :-)
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 29-01-2004, 02:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
That is a very cool scooter. I bet it zips along quite fast. Could you PLEASE post some pics of the drive system? Thanks.
Unread 29-01-2004, 21:03
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Here it is. http://www.chiefdelphi.com/pics/bin/107542728548.jpg Sorry it isn't more "revealing" but the jist of it is the shafts of the two motors have been pressed into either end of a machined aluminum slug, and the aluminum U channel that they're mounted on is hinged. There is a threadded stud that pulls the U channel down, and the aluminum slug that is pressed onto the motor shafts is forced down on the wheel. When the motors run, the aluminum slug rubs aganst the wheel, and spins it. It's a very crude system, but it works surprisingly well. However, there are some inherent problems: If you don't apply enough pressure on the slug, it will slip on the wheel and take chunks out and/or melt the wheel. If you apply too much pressure, you could hurt the CIM motor's bearings. Because of the fact that it is a FRICTION drive, it looses alot of energy as heat, which gets dissapated by the frame. Also because of the constant deformation and wear on the wheel, I go through one every 15 charge cycles or so. - Rotating the wheels every few cycles helps prolong their life.
As for speed, it zipps along - I used to ride it to and from classes, but my school's administration banned me from riding it inside - The excuse "It's a Tech. project" wore off really quickly (I think they're jealous).
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 28-07-2004, 09:48
Elgin Clock's Avatar
FRC #0237 (Black Magic)
That stinks.. lol
Quick question if I may. How did you make the motors turn the same direction even though they are reveresly mounted from each other??
(if this answer is really simple I'm gonna fell stupid, so please make it sound complex.. lol)
Can I just guess that you hooked one motor positive/positive-negative/negative and the other positive/negative-negative/positive?
Unread 29-07-2004, 13:21
fox46's Avatar
You guessed correctly
Unread 29-07-2004, 13:24
Yay.. I'm smart..
Thanks for the info..
Unread 31-07-2004, 03:03
mtaman02's Avatar
I am so tempted to build me one of these about how long the batteries good for and aproximate weight
Volunteer Resume:
Unread 31-07-2004, 12:01
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
So if I understand correctly, you essentially press the chia's shaft up against the wheel? Man, that IS crude.
How hard do you think it would be to put some gearing on the back wheel?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 31-07-2004, 12:41
occra 23.
AKA: ryo
None #1481
just a bit harder than a friction drive.. actually, i think cutting the rear end off completely and rebuidling a whole new rear end with a gearbox would be easier than attempting to squeeze somthing into what is already made compact........
hey! how about some 4 speed gearboxes!! with a clutch, of course so you can really rev it and drop the clutch to burn some rubber..... or in this case, the tires arent rubber are they? well, then.. we need to get black rubber tires so the janitors can yell at us for putting too many rubber marks in the hallways!
Unread 31-07-2004, 17:51
phrontist's Avatar
Proto-Engineer
GreenCactus:Genius!
This is an excellent way to get some offseason practice in the fabrication of transmissions!
w00t!
It's got everything going for it:
  • It's Cool
  • It's an accurate simulation of the stresses endured by a robots gearbox. (A bit tougher I suppose...)
  • It's fairly easy
  • It's cheap
So now my project is to make one of these with a four speed. A truly cool thing to do would be do make shifting automatic...
Unread 31-07-2004, 23:49
occra 23.
AKA: ryo
None #1481
i just noticed... are those two batteries? im guessing in parallel? is that just to have more run time? and also just to use up some space left over?
OR, is that running at 24V? many motors can take quite a bit of current abuse without burning... of my whole robotics career..(short, but..) ive only burned two drill motors... and that was during my first OCCRA season. and wheelchair motors, which were supposed to be run at 12V, were fine running at 24V.. for an entire battery charge cycle..well of course they got quite hot, but still they are fine. and ever played with those small motors rated 3V? the ones that come in the small handheld batterypowered fans... well, those, you can run them at 9V for quite a while. i dont think there's more rpm with the 9V than with a 7.2V though. didnt have a way to test it, so just a thought. perhaps sumthing to do with heat and efficiency... soooo, if you run the chips at 24V, how long will they last? anyone tried this before? i dont have any to spare so cant test it myself... id like to know how long itll last with some resistance. not a freespin...
Unread 05-08-2004, 18:40
cadman2k5 cadman2k5 is offline
AKA: steve lami
#0637 (Horsepower)
Team Role: Student
cadman2k5 is on a distinguished road
Send a message via AIM to cadman2k5
LOL I definately want one of those... my birthday is March 15... if it helps.
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
Dean on 60 Minutes 2 archiver 2001 7 24-06-2002 00:14
Any Super Robots Yet? SuperJake General Forum 9 25-01-2002 17:47
