Go to Post Every year, everyone reads too much into the hints given by Dave. - EricH [more]
Unread 28-01-2004, 16:59
Stormhammer's Avatar
Stormhammer Stormhammer is offline
Team 1183
AKA: Justin
#1183 (Eagle Executioner's)
Team Role: Driver
Stormhammer can only hope to improve
Send a message via AIM to Stormhammer Send a message via Yahoo to Stormhammer
Question tank drive
just wondering if anyone has or knows of a site that has the programming code for a single joystick tank drive... if not, can someone give us an example one ( preferably one that worked )
1-2-3 EXE... prepare to be executed - Eagle Executioners ( no more Eagle Engineers ) #1183
Its either a Mopar or no car
Dude, WHY ARE YOU SO SLOW?!?!
Unread 28-01-2004, 17:03
Re: tank drive
see line 224 of the user_routines.c in the default code
Unread 28-01-2004, 21:12
Team 1183
AKA: Justin
Team Role: Driver
Re: tank drive
your gonna have to explain that. The guy thats programming is a new guy on the team, he knows C and that, but yeah, just want to make sure there aren't any confusions anywhere. Thanks
Unread 28-01-2004, 21:31
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: tank drive
void Default_Routine(void)
 /*---------- 1 Joystick Drive --------------------------
  *  This code mixes the Y and X axis on Port 1 to allow one joystick drive.
  *  Joystick forward  = Robot forward
  *  Joystick backward = Robot backward
  *  Joystick right    = Robot rotates right
  *  Joystick left     = Robot rotates left
  *  Connect the right drive motors to PWM13 and/or PWM14 on the RC.
  *  Connect the left  drive motors to PWM15 and/or PWM16 on the RC.
  pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
  pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
Of course, my thought is to use X for left and Y for right. But that's counter-intuitve. Really counter-intuitive
Unread 28-01-2004, 23:06
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Re: tank drive
Another way to think of this is to convert the IFI joystick values into signed values (e.g. -127 to 127) then simple math to mix, then simple math to limit and finally simple math to convert back to 0-255 for the Victor. The IFI example code was lifted right out of the Pbasic code from last year. Pbasic didn't understand negative numbers (it was truely wretched...) hence the bizzare mixing code.
char limit(int val)
if (val > 127) return 127;
if (val < -127) return -127;
return val;
void user_routine(void)
int Left = p1_y - 127; // Convert to signed #
int Right = p1_x - 127;
pwm01 = limit (Left + Right) + 127;
pwm02 = limit(Left - Right) + 127;
etc.
Unread 29-01-2004, 13:41
AKA: Jamie Bliss
Re: tank drive
Speaking of each, what is the difference in storage between signed and unsigned? is it if bit1=true then # is negetive, or is it an offset, like (Signed) 0=(unsigned) 127, as an example.
Unread 29-01-2004, 14:38
Re: tank drive
Signed math just tells the compiler to interpret the bits differently. Internally the CPU uses something called 2-complement to represent the negative numbers. A number in 2-complement form can be added to another number and you will get the right results without any special hardware. However, you can't generate a 2-complement number by simply flipping the sign bit (bit 8). For example: 0x01 2-complement is 0xFF. 0xFF is 255 in unsigned math.
So, to represent a negative 5 in binary, you would complement 00000101 to get 11111010 then add one to get 11111011
So, add -5 and, say, 7 (in binary):
11111011
00000111
100000010
The 9th bit falls off the end of the earth (or into the "carry" bit) and the resulting number is just 2. When adding larger numbers (int, short long and long) the bytes are added sequentially and the carry from the previous add is added into the first bit of the next.
When converting shorter to longer (e.g. a byte to an int) you simply copy the 8th bit into all bits of the next higher byte and the value is preserved. This is all done for you by the compiler.
Unread 29-01-2004, 16:08
AKA: Jamie Bliss
Re: tank drive
so 5 = 00000101 and -5 = !5 + 1 = 11111011
Or did I mis-read that?
I'm just curious, so one has a vague idea what happens if you pass a signed to a unsigned.
Unread 29-01-2004, 22:19
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Re: tank drive
Well, if you do something like this
unsigned char u_char;
signed char s_char;
u_char = s_char;
The maping will be as follows:
s_char >= 0 : u_char = s_char
s_char <0 : u_char = 256 - s_char
Hope that answers your question... (Note I'm speaking in terms of this micro and this compiler, YMMV on other systems...)
Unread 29-01-2004, 22:53
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
Re: tank drive
Speaking of programming tank drives, ours threw me for a loop tonight. We had run last saturday w/o problems, and then tonight, our x and y values got switched. basically, to drive straight, we had to move the stick left or right, and to turn move it up or down. To fix it, i just changed the order in the default program for one stick mixing. Does anyone know what caused this/ how to fix it? Im lost, thanks.
-Josh
Unread 29-01-2004, 23:02
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: tank drive
did one of your motors have its polarity reversed? that would cause the exact problem you are experiencing. (it happened the first time we tested the bot, we switched the polarity of one motor, which fixed it)
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 29-01-2004, 23:08
#0316 (LuNaTeCs)
Re: tank drive
Thanks for the quick response. Actually that also happened the first time we ran, but we changed polarity, not code. Ill check and see if someone switched it again.
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
Rookie team drive tream idea Max Lobovsky Technical Discussion 18 21-01-2004 03:36
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
