Go to Post If they ask you to stop - you stop. - techhelpbb [more]
Unread 19-01-2004, 19:15
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Multi-pin Connectors
Does anybody have any good references to places where we can purchase multi-pin connectors? I would like to have a connector similar to a battery connector for an RC car or even the QuickConnects 6 awg connectors but with many pins (upwards of 20). Any advice?
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 19-01-2004, 19:37
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Re: Multi-pin Connectors
First, try checking the almost-identical thread right below this one before posting a new thread.
Second, in that thread I posted the Digikey part number for those 4-pin snapping/locking connectors found in computers. Download the catalogue PDF, ctrl+F those part numbers, and find the 20-pin versions.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 19-01-2004, 19:53
Actually, I had read that thread before posting this. When I read it, you hadn't posted that information and the only posts in it referred to purchasing spare servo cable and connectors. Still, thanks for the info.
Unread 19-01-2004, 20:04
Umm Errr...
Adnerson power products(the people who make the battery connectors in the kit) sell some stuff you might be interested in. Newark is a distributor, so they are FIRST legal.
http://www.andersonpower.com
Btw. What exactly are you tryign to do? If i knew a little better, i might be able to suggest something a little more specific. Are you tryign to mount all your speed controllers etc on a single quickly removable plate?
1139 Alumni
Unread 19-01-2004, 20:19
Crusty Mentor
FRC #0097
I noticed that too, but I meant that with all these complaints about useless threads, there shouldn't be two threads asking for slightly different versions of essentially the same thing. I think rather than posting a new thread, you should have posted a question in the existing thread. Nevertheless, this discussion doesn't belong here, so just enjoy the info. If its not quite what you were looking for, ask me and I'll see if I can help you out.
Dan L
Team 97 Mentor
Unread 27-01-2004, 12:51
D.Stephenson's Avatar
D.Stephenson D.Stephenson is offline
AKA: Denise
FRC #0871 (West Islip Robotechs)
D.Stephenson is on a distinguished road
Send a message via AIM to D.Stephenson
Last year we used multi-pin connectors from Phoenix. They do make a size large enough for the #10 wire. This way, we were able completly disconnect our control board and remove it from the robot. By using the same wiring configuration, we can use last year's board as a test bed for this year's robot.
Unread 27-01-2004, 23:08
Do you have a link to the Phoenix website? I have been searching for their site but I can't find much useful information.
Unread 28-01-2004, 22:37
CNCBoy461's Avatar
CNCBoy461 CNCBoy461 is offline
Spaz
AKA: Matt
#0461 (WBI (Westside Boiler Invasion))
CNCBoy461 is an unknown quantity at this point
Send a message via AIM to CNCBoy461
Molex also has an alternative that seems to work, however, they are not cheap: http://dkc3.digikey.com/PDF/T041/0103.pdf that’s the whole page, but the "Mini-Fit Sr. Terminals" and the "Mini-Fit Sr. Connectors" are what I am referring to. The Connectors have a max of 6 pins which would be 3 motors per block and a current rating of 50 amps. Good Luck.
WBI Team 461
Let's All Go Nuts!
ROBOTS! ROBOTS!
CNC Master...6061, the prefered metal of choice
Unread 28-01-2004, 22:50
I have been looking at the Powerpole connectors from Anderson Power. I was wondering if anyone knew where I could buy them? I called Anderson and they gave me the names of some distributers but the ones I could reach wanted a minimum order of 25 connectors (when I only want 4). Any suggestions?
Unread 29-01-2004, 14:26
AKA: Denise
The web site for Phoenix is
www.phoenixcontact.com
To help you narrow it down, look in the COMBICON catalog section. There may also be a section where you can select you requirements, (ie number of positions, wire size, ampere rating, etc) and the web page will kick back with a few appropriate selections.
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
PBASIC access to 1 pin only diego25 Programming 13 21-01-2002 10:55
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
