Go to Post I was on the same plane as 365 returning from Atlanta to Philadelphia last year. The whole rear half of the plane was neon green. - Lil' Lavery [more]
Unread 29-01-2004, 17:11
MADCOW's Avatar
MADCOW MADCOW is offline
Ninja Cow
AKA: Chad Sobodash
#0201 (The FEDS)
MADCOW is an unknown quantity at this point
Send a message via AIM to MADCOW
Exclamation Pin-outs for the joystick?
Hi! I'm from the FEDS. Does anyone have the pinouts for the standard "ADB" joysticks? I can't find them anywhere! Please help ASAP!
Unread 29-01-2004, 17:19
Re: Pin-outs for the joystick?
did you check the documents at the innovation FIRST website?
the joysticks have to match the pinout onthe operator interface
http://www.innovationfirst.com/FIRST...umentation.htm
Unread 29-01-2004, 17:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Check the FRC default code Doc. that should have it.
Unread 29-01-2004, 17:31
MADCOW's Avatar
Ninja Cow
AKA: Chad Sobodash
#0201 (The FEDS)
Whoops! Thanks! I was looking for a direct joystick pinout. Heh. Thanks bunches!
Cable Pin outs Wetzel Electrical 8 10-01-2004 13:50
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
