Go to Post we've got three years to perfect it. And then... who knows? - Amanda Morrison [more]
Unread 29-01-2004, 18:52
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Getting off CMT pulleys
Gosh darn it. I installed a CMT pulley and I did not know that it would be permamently stuck on the globe motor. Does anyone have any ideas of getting them off of the shaft?
Unread 29-01-2004, 19:12
Umm Errr...
Re: Getting off CMT pulleys
What's a CMT pulley?
1139 Alumni
Unread 29-01-2004, 19:23
Adam Y.'s Avatar
Adam Y.
no team (?????)
They are just a pulley with a special hub that was in one of the robot kits.
Unread 29-01-2004, 21:59
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
If I recall correctly, putting the set screw in the other hole releases the hub if you didn't over torque the screw in the first place.
Unread 30-01-2004, 07:08
Jack21 Jack21 is offline
Jack21 is an unknown quantity at this point
you could try a small gear puller (common at most flea markets)
Inventor part -> 3ds max? DanL Inventor 7 12-12-2003 08:17
tool and part names angier314 Chit-Chat 0 23-04-2003 19:12
Can we use part of a container on our robot? Rick General Forum 1 10-02-2003 20:10
Can I reduce the number of similar part files? roknjohn Inventor 2 29-01-2003 21:36
team 497 needs a part Andrew Dahl General Forum 0 25-02-2002 13:22
