Go to Post "Nuclear" is pronounced "nu kli Er." It is NOT pronounced "nu kU ler." When you use this pronunciation, no matter how smart you may actually be, you sound like an illiterate dolt (are you listening, Mr. Bush?). - dlavery [more]
Unread 21-02-2002, 14:11
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The Mechanical Bulls present. . .
Okay, so the kids are really proud of their machine, and I *know* you've all been itching to see some pictures.
So, we're proud to show the first pictures of the *almost* complete robot, El Toro.
http://www.chiefdelphi.com/forums/pi...rrow=4&trows=3
An overview. . .you can't really make out much but the shape.
http://www.chiefdelphi.com/forums/pi...&action=single
A close-up of the front end.
http://www.magenet.com/~imagination/ElToro/backside.jpg
http://www.magenet.com/~imagination/ElToro/cover_on.jpg
http://www.magenet.com/~imagination/...front_view.jpg
It's a monster drive train (66.2 lbs!!), and we'll be able to viciously handle one goal. . . we'd planned on two, but the aforementioned drivetrain weighed a bit more than I had anticipated.
If you've got questions, I've got answers
Cruisin' and bruisin',
--Madison--
...down at the Ozdust!
Unread 21-02-2002, 14:14
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Please tell me your wheels are attached by more than that little connector. As far as I can see, that's all that's holding it on. Those aren't particularly strong and that's going to be taking a lot of force.
Matt
Unread 21-02-2002, 14:22
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Are you guys 130lb friction limited? From what i can tell every team out there can spin it's wheels on the carpet.
I like the drivetrain, my team's train also weighed in heavy, whats your guy's top-gear speed (ours is geared for about 5-7 ft/sec)?
Looks like a battlebot,
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 21-02-2002, 14:45
Madison's Avatar
FRC #0488 (Xbot)
Matt
Well, even though we've already discussed this . .
Yes, the axle plates are held in by more than the gusset. They're bolted to the extrusion on the inside, and the entire wheel assembly is fixed by vertical posts in the center - to prevent sliding in the extrusion.
--Madison--
Unread 21-02-2002, 14:47
Madison's Avatar
FRC #0488 (Xbot)
Greg
It's meant to be tough. It's a pusher of extreme magnitude.
Our top speed is 10+ ft/s. Our low speed is about 4.5 ft/s.
--Madison--
Unread 21-02-2002, 15:25
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Yes, we have a very poerful low speed. We pushed a 150 lbs or so man down a tile floor. I'm almost scared about controlling that much raw power on the carpet.
When we pushed the guy down the hall, there were some kids from Hauppauge (another local team), and they were convinced when they manuvered their robot correctly, nothing would move them. Well, by the looks on their faces when we went down the hall, i have a feeling we'll be one of the more powerful robots at the LI regional. Now that i said that though, there's gona be someone even more powerful than us.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 21-02-2002, 15:49
What i ment was, can you lift the goals to get more traction? I hate to sound this way but if your just using your 130 pounds for traction/friction you are not going to be a whole lot more powerful then other teams (unless you get a running start, oh boy ). My team dragged a 200 pound person on carpet, if you think about it the surface dosn't matter, since friction is reduced for your wheels and the body of the person your dragging on tile. Oh well, it dose look like a beast of a robot!
Greg
Unread 21-02-2002, 16:23
Madison's Avatar
FRC #0488 (Xbot)
Greg
No, we can't currently lift the goals off the floor, so we don't have the added benefit of adding additional weight onto our robot.
Instead, we have a far greater contact area with the field than most teams, with a very, very 'toothy' belt. To be honest, I'm quite a bit more familiar with the design than it's actual performance just now. I only got to see it working for a short period of time.
The most impressive thing about dragging an adult down the hall, I think, has less to do with the weight we pulled and more to do with the idea that there was no slippage in our drivetrain whatsoever. That was on linoleum. Carpet, of course, provides significantly more friction, and a better surface to react against.
--Madison--
Unread 21-02-2002, 16:25
Mark Jones Mark Jones is offline
Engineer - Team 343 MIM
FRC #0343 (Metal-in-Motion)
Mark Jones will become famous soon enoughMark Jones will become famous soon enough
Send a message via AIM to Mark Jones
Mechanical Bulls, Weight Transfer and Traction
Weight transfer is the answer to getting traction. Check out our two short videos of our robot crabing two goals in one and pushing close to 1/2 ton in the other. Notice that we are tranfering some of the goal weight onto our bot for improved traction.
Check it out at: www.metalinmotion.com
Unread 21-02-2002, 17:34
Bob Drexel Bob Drexel is offline
Bob Drexel is an unknown quantity at this point
Question How much??
Mike,
How much force can the drive system push/pull with? How much loses are in that complicated belt drive system? Have you tried to calculate out any of these numbers?
Unread 21-02-2002, 17:46
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
speaking on behalf of my team
what we are amazed about is we had enough friction on lenoleun without any exttra weight. this also enables us to move much faster than other robots that puts half of the weight of two goals. by dragging two goals one also has to ensure that all of the wheels are facing the correct way.
that day we were also surprised that the whole time we didn't blow one fuse. and that was 210lbs 32ft down a lenoleum hallway. we really aren't scared of slipping!
______________
"Ian"- don't worry about controling the beast on the carpet because i will be right there with ya to make sure you don't screw up my beautiful peice of technical and BruteForce achievement!
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 21-02-2002, 17:54
College? What?
So, Mr. Drexel finally found the forums. Steve must have shown him. Tell us, how hard was the robot pushing you down the hall, cause you looked surprised that it seemed to be quite a bit stronger than you.
AIM --> Woloi
Unread 21-02-2002, 18:03
aKa - Steve Bennett
FRC #0125 (NUtrons)
Steve is also trieing to find out what Bob thought about the pushing down of the hall. So what did you think MR BOB?
Team
....Uh, GO NUTRONS!
Unread 21-02-2002, 18:05
aKa - Steve Bennett
FRC #0125 (NUtrons)
so mike did you get any sleep lately?
wel anyway what is the force put out by our BruteForce Beast?
Team
....Uh, GO NUTRONS!
Unread 21-02-2002, 18:31
I guess im wondering what you do differently? Do those belts have any danger of damaging the carpet? They will probably help a great deal, but if they slip they are going to really make a mess.
Your probably not the only team that can pull people around on tile. I bet my team's robot could do that, we just didn't try. Remember that friction = u * Fn so you either increase the coeficient of friction or the force normal. Traction is different, and it looks like traction is what you exel at.
heres a video:
www.startateam.com/639/movies/2002_build_1.mpg
Hope to see you guys do well.
Greg
Where can I learn some mechanical before build season John JediMaster General Forum 7 23-09-2003 20:27
Mechanical Engineering archiver 2000 0 24-06-2002 00:04
How to beat Mechanical Mauraders Aaron Lussier General Forum 33 16-06-2002 21:27
Are your mechanical team's suffering withdrawl??? Elgin Clock General Forum 13 23-02-2002 11:19
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
