Go to Post "If everything is possible, there is the possibility that something is impossible..." ::sigh:: :) - Kims Robot [more]
Unread 29-01-2004, 16:59
supergrover supergrover is offline
AKA: Chris Warren
FRC #1397 (Ajax Rams)
supergrover is an unknown quantity at this point
Window Motor With Spike/Victor
Can we use the window motor with both the spike and victor?
Thanks so much!
Unread 29-01-2004, 17:02
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: Window Motor With Spike/Victor
You cannot use both on one window motor. The spike controls just straight on or off and the victors control anywhere from 1 to 254, 127 being neutral. If you want more than one speed you'll have to use a victor, but if one speed is all you need then I would go with a spike because they are cheaper and lighter.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 29-01-2004, 17:04
AKA: Chris Warren
Thank you for your quick reply!!!!
Unread 29-01-2004, 17:25
actually thats an interesting question, but if you put a victor after a spike, then when you reversed the direction of the spike the victor would have its + and - connections to power backwards
and all the smoke would leak out.
Once it leaks out its really hard to get it back in, and it seems to be necessary - the victors dont work without it!
and if you put the spike after the victor, you would have the same problem.
Unread 29-01-2004, 18:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If you ran the Victor in only a single direction and had the spike after it you should be able to control the Victor proportionally in one direction and reverse the direction with the spike aftwerward. I haven't the slightest clue why anyone would do this though. If you had only a forward speed control it would make it reverse for fairly cheap.
Anyway, for those of you who don't know, what I said above in this post is strictly disallowed on a FIRST competition robot and I make no guarantees regarding the well being of your electronics if you ever try something like this.
Unread 29-01-2004, 21:24
AKA: Chris Warren
Sorry about the confusion guys...I was wondering if the window motor could be used with the spike OR the victor...we werent going to use both at the same time.
Thanks for the info...response time in here is great....appreciated by us rookies!
Unread 30-01-2004, 08:00
if you did put a spike after a victor, even if you never reversed the victor, Im not sure if the spike would work correctly
it may only operate with 12V across its input side - the victors work by pulsing the output on and off (pulse width modulation)
I dont know if the spikes woud function that way.
All this is against the FIRST wiring rules - but it is interesting to think outside the box and gain some insite into how these devices operate.
BTW - I was pretty sure the original poster was asking if you could use either one, not both - but someone else would read this thread thinking we were saying you could use both, and would try it - so all this clarification is here for a good reason.
Unread 30-01-2004, 13:04
AKA: Chris Warren
Thanks to everyone! Gracious Professionalism at its best!
Unread 30-01-2004, 15:21
This is only the beginning. Just look all over theses boards and read the immense amount of help being given. And once you know some people and discover the PM feature, it becomes the worlds greatest robotics resource.
Unread 30-01-2004, 15:38
not only that! some of us are spendid to behold!
(Im scared, someone behold me! :^)
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
Nippon Denso Window Motor Specs RichardBCR Motors 13 26-01-2003 07:01
window tape archiver 2001 1 23-06-2002 23:51
Looking for window kit parts archiver 2000 2 23-06-2002 22:50
Re: window motors archiver 1999 1 23-06-2002 21:56
