If you're using two wheel drive, you should loose almost every pushing match against and four wheel driven robot, simply because half of your weight (approximately) will be dragging instead of being pushed. I can not stress enough that you need to have all wheels in contact with the ground be powered if you plan on using a simple tank style drive and wish to be competitive. The pneumatic wheels are very light, and drivetrain is by far the most important part of your robot. Don't cut power to two wheels because of weight unless you plan on doing something so specacular with the other 5 or 8 lbs that if offsets the immense disadvantage you'll be at from having half of the pushing/pulling force. I plead that you'll reconsider having unpowered wheels if you haven't finallized your design already. Matt |
Re: Gear Ratio help....plZ..someone???
I think it's also fair to assume that unless you have a crab or swerve style drive system, the manuverability increase isn't too significant between a tank style 2 and 4 wheel drive system. This is what my experience has shown, hopefully yours has been different. Again, good luck! Matt |
| Help with gear ratio | Wayne C. | General Forum | 6 | 26-01-2004 12:30 |
| confuzzling gear ratio definition.. wanna clear this one up? | archiver | 2001 | 5 | 23-06-2002 23:13 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drivetrain Help | Jordan | Technical Discussion | 16 | 02-12-2001 12:14 |
| Drill motor gearBox question | Dennis Hughes | Motors | 4 | 11-10-2001 07:11 |
