Go to Post DONT USE ROBOTS FOR EVIL!!! - Cooley744 [more]
Unread 30-01-2004, 22:12
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
Quick inventor question
i don't really know a lot of inventor yet but when i get the dimensions in an idw drawing, it only shows the dimensions to 2 decimal places. is there any way to change that?
Unread 30-01-2004, 22:19
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Re: Quick inventor question
press the sketch the click the first button on the upper left and clik a face where you want to "extend"
Unread 30-01-2004, 22:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I know what youre talking about. Go to Tools on the main toolbar, then click Document Settings. Once in Document settings, click on :Lin. Dim. Display Precision. Change it to the appropriate number of decimal places. If this doesnt work, feel free to IM me at "Coryteam100" for help.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 30-01-2004, 22:37
i tried what you said but those options in document settings but the units tab isn't there when i have an idw drawing open
edit
never mind, i found it
Unread 30-01-2004, 22:56
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
edit
Right click the dimension -> tolerances -> percision
Keep in mind that percision indicates tolerances unless a tolerance is otherwise called out.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 30-01-2004, 22:57
yea i just found that, is there a way to do it to the whole document though?
Unread 30-01-2004, 23:08
I'm not sure. It is good practice to set them individually though. The default is two decimal places for a reason. Specifying tighter tolerences for a dimension is not a trivial action and some serious consideration should be put into it.
What I'm trying to say is you should start at two decimal places then decide on the tollerances for each dimension as you go. This may sound odd but is good practice.
There is probably a way to do it though. Try editing the default ANSI format settings.
Greg
Q&A Discuss: Quick C Programming Q CD47-Bot Extra Discussion 6 16-11-2003 11:16
A quick and entertaining lesson Veselin Kolev Chit-Chat 12 19-08-2003 12:28
Quick question about the ramp archiver 2001 5 23-06-2002 22:45
Quick, need help with two indefinite integrals! WakeZero General Forum 2 20-05-2002 14:17
Quick Question, i guess Andrew Rudolph Motors 1 12-08-2001 14:39
