Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Unread 31-01-2004, 15:36
Paradox1350's Avatar
Paradox1350 Paradox1350 is offline
FORMER Captain now Jealous Onlooker
None #1350 (Rambot)
Paradox1350 is on a distinguished road
Newbie Autonomous Question(s)
I'm from a rookie team and we are having some coding issues. We have one member on our team that can code just about anything, but he can only come about one day a week. Meanwhile, we are trying to accomplish things on our own. Everyone else that is working on coding began learning C about, oh, last week. Meaning we're all clueless. Really, really, seriously clueless.
We are trying to get the autonomous mode to work. The problem is we have no clue where to begin. We don't even know where to find the source code that is supposed to be on the FIRST site, or so we've been told.
Basically, we need a STEP BY STEP guide on how to begin our autonomous programming. We need to know how to initialize an autonomous mode, how to set it up to follow sensors, and how to set up a programmed list of directions (i.e. "Move forward 10 feet, turn 30 degrees, etc.")
Any help would be GREATLY appreciated.
Unread 31-01-2004, 16:21
AlphaOmega870 AlphaOmega870 is offline
AKA: Mike
#0870 (Southold RICE)
AlphaOmega870 is an unknown quantity at this point
Send a message via AIM to AlphaOmega870
Re: Newbie Autonomous Question(s)
the default code can be found at www.innovationfirst.com
also, the place for putting default code is found in the user_routines_fast.c file.
Unread 31-01-2004, 16:23
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
Click on "FIRST Robotics" then on "Documents" at the top. The source is on that page.
Look in ChiefDelphi's white papers for help on getting started...there are 3-4 papers on just that.
If you need more help, PM me and I'll be glad to help.
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 31-01-2004, 21:11
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Well, I'll show you some code so you can get a start on it. The other stuff should be pretty similar, or at least require a similar level of thinking -- so once you understand what's going on here, you should be well on your way.
First, let's say you want a function 'void Turn_Robot (int angle)' to turn the robot by some specified angle 'angle.' How do you do this? Well, without encoders or gyros, the answer is pray! But you'll have to settle for a simple counter. E.g.,
      Hopefully you can follow this.  I'll try to comment liberally (something that's rather hard for me ;)
      In your auto mode routine, you might say something like:
      if (!FinishedTurn) Turn_Robot (radian measure);
      else  {/* put other code here */}
      Note that you'll need a global variable FinishedTurn, initialized to false (0), and a handfull of defines.
     // static means that we only set it to 0 the first time, and when it is
     // called again, it is persistant, meaning it won't lose its old value
     static unsigned int counter = 0;
     // we are going to count up from 0.  On the left side of the equation, we
     // have a unit of cycles, so we have to find out how to convert radians
     // to cycles.  This is done by an *emprically found constant*
     // CYCLES_PER_RADIAN (dependent on voltage, so beware).
     if (counter++ > abs(angle) * CYCLES_PER_RADIAN)
     {		// Robot has finished turning, ergo ...
        // we're done, so nicely set counter back to 0 for next time
        // set left and right drive to neutral, and set flag FinishedTurn to true
        counter = 0;
        LEFT_DRIVE = 127;
        RIGHT_DRIVE = 127;
        FinishedTurn = 1;
     else {
        // We aren't done turning.  We have to set up some convention for
        // angle (turning PI/4 radians doens't mean anything without a
        // coordinate system, afterall!)  Ergo,
        if (angle > 0)
        {	// Positive angle means turn left
            LEFT_DRIVE = LTURN_SPD_LDRIVE;
            RIGHT_DRIVE = LTURN_SPD_RDRIVE;
        else {	// Negative angle means turn right
            LEFT_DRIVE = RTURN_SPD_LDRIVE;
            RIGHT_DRIVE = pwm04 = RTURN_SPD_RDRIVE;
        FinishedTurn = 0;  // NOTE: set this back to false; else, when called
                                 // after successful move, it will still be true!
A similar Move_Robot function should be easy (the turn is slightly more complicated, so that's why I included this one for you). Now, how to find out all those constants? Well, that's the fun part (by the way, I put in their radians as the default, but you can set it up to any unit you feel like).
Okay, set the constant CYCLES_PER_RADIAN to some value, any value (I'd guess what you think, from judging how fast the robot can turn). Don't do anything in your code, but call the function Turn_Robot (angle), with some angle you feel like turning. If the robot doesn't turn enough, increase the constant by a variable amount, depending on how much is left to turn. If the robot turns too much, decrease the constant. (You might want to put tape on the floor marking off a 45 deg angle, or some such sort that is easily determined, so you can quickly tell what to do.)
Oh, and I haven't tested this code, so beware (I'm frequently wrong ) As Knuth said, Beware, I've only proven the above code correct, I haven't tested it.
Unread 31-01-2004, 23:14
[53] opticruzer [53] opticruzer is offline
[53] opticruzer is an unknown quantity at this point
Send a message via AIM to [53] opticruzer
well if u download the source codes from the sites listed above, they come ready to work. make sure u wire up the beacon right. to start try to see if ur senors pick up the beacon by using the tracking code. if the works then use teh navigate code. oh make sure that u use two of the same type servos or it wont work right. we had to fix this in the code to. this should get u started. make sure u hit the trigger when using the navigate code or it wont start.
Unread 01-02-2004, 00:23
shsdragon shsdragon is offline
shsdragon is on a distinguished road
Send a message via AIM to shsdragon Send a message via Yahoo to shsdragon
rokkie needs help
k i am from a first year team from fl and basically we have alot of problems with programming some kid told me bout encoders and buildin a cirui would be the best way to go if any one can help me plz help
Unread 01-02-2004, 02:57
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Unhappy Re: Newbie Autonomous Question(s)
Don't feel too bad...We're clueless too! And to make things worse, they never sent us the CDROM that was supposed to come with the new Edubot Controller, so we didn't even have the CBot compiler until I borrowed a copy from another team! If you find that step-by-step let us know!
Unread 01-02-2004, 03:05
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: rokkie needs help
if you need help, the best method is to try and figure something out, and when you get stuck on a particular thing, ask a specific question. we can't really show you the entire process (message boards aren't very good for that), but we can definitely try to answer specific questions or provide advice on specific topics.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 01-02-2004, 11:05
http://www.rec.ri.cmu.edu/education/...tent/index.htm has a lot of tutorials that are very helpful, such as running a motor for 1 second, and another one called making a timed turn.
Unread 12-02-2004, 19:47
ZuniHigh ZuniHigh is offline
ZuniHigh is an unknown quantity at this point
I'm following the instructions in the 2004 introduction to programming guide, but when i followed their instructions to insert the code b/w the "Getdata" and "Putdata", but when i pressed the make button, it did not compile. What is wrong?
Unread 12-02-2004, 22:36
Saying that it didn't compile without giving us any error messages is not helpful at all. You should also show us the exact modifcations that you did.
Unread 13-02-2004, 00:41
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Our robot will not follow a line of tape. (The banners are calibrated correctly.)
Let me explain our setup:
pwm01 = Left Drive Wheel
pwm02 = Right Drive Wheel
rc_digi_in01 = Left Banner (WHITE Sig.)
rc_digi_in02 = Right Banner (WHITE Sig.)
Our Autonomus Code:
PHP Code:
if (rc_dig_in01 == && rc_dig_in02 == 1
pwm01 117;
pwm02 117;
        if (
rc_dig_in02 == && rc_dig_in01 1
pwm01 117;
pwm02 113;
        if (
rc_dig_in02 && rc_dig_in01 == 1
pwm01 113;
pwm02 117;
        if (
rc_dig_in01 && rc_dig_in02 1
pwm01 137;
pwm02 137;
Our pwm output is reversed since we are driving the robot backwards in autonomus mode. (The locations I stated above are in autonomus mode.)
The problem is our robot will not do anything if the sensors are not seeing the tape. It just stops.
We are clueless, and any help would be appreciated. (This is the first time I worked with any C[++] programming other than the old "Hello, World!" program. (If you see any bugs in our code, please respond! ))
LBK Rules; VB Programmer being suddenly forced to C by FIRST (or IFI, I don't know which). (BTW: I just got back from a meeting about an hour ago.)
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 13-02-2004, 08:51
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Our Autonomus Code:
PHP Code:
pwm01 117;
pwm02 117;
        if (
pwm01 117;
pwm02 113;
        if (
pwm01 113;
pwm02 117;
        if (
pwm01 137;
pwm02 137;
Couple of problems:
First, when you're going off the line, you correct yourself wrong. If your left sensor goes off the line, you drive the right side harder, meaning you actually go further left. That's an easy mistake to make.
Second, somebody correct me if I'm wrong, the pins are pull ups, meaning that they are normally 1, unless they recieve a signal, which makes them 0. So you need to switch the test for 0s and 1s.
Third, make the power that the motors are driven at a little higher. I'm not sure if your problem was that it wasn't moving, but the way it is now, it will either move really slow or not at all.
P.S. Being a newbie isn't bad. I'm on a newbie team too.
Unread 13-02-2004, 09:07
The banner sensors have two signal wires, one of which is Normally Open and one of which is Normally Closed. So, his code is correct (in that aspect), assuming it is wired correctly.
Unread 13-02-2004, 09:14
Programming User
Oh, yeah, forgot that. Well, make sure you have the correct wire attched.
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
variable? manodrum Programming 11 01-04-2003 17:20
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
