Go to Post Okay guys I am enabling the robot. Honestly I have know idea what it is going to do. SO MOVE!! - JulieB [more]
Unread 31-01-2004, 17:42
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
QBASIC Dashboard Program
Hello Everybody,
I have started working on a dashboard program in QBASIC for this year's OI. I chose QBASIC because it is simple enough, and I know how to do some things in it.
I have already been able to open the serial port, detect which frame in incoming, and store the input stream in a 26-byte arrary. However, I am having a strange problem when attempting to display the values. If I use print to output the parts of the array, I get the ascii character representing the byte in the element of the array. This is a problem, as letters and ascii symbols are not easily parsed by humans. Is there a way that I can output data from the print command, out of a character variable, in a decimal format?
Also, for those teams working on a dashboard program, do not repeatedly set and unset the DTR pin. The OI tends to act flakey until it is reset if you do so.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 31-01-2004, 18:38
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Re: QBASIC Dashboard Program
It's been SEVERAL years since I've touched QBASIC, but I'm about 90% sure you're looking for the ASC$ function.
PRINT ASC$(A)
Unread 02-02-2004, 07:28
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Can you download programs to the '04 OI? How?
Unread 02-02-2004, 08:51
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
No, the OI is not programmable.
Unread 02-02-2004, 09:36
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
The idea with a dashboard program is that it is run on a computer that is hooked up to the dashboard port on the OI. The OI reports this information through the db port, and then the program picks up the bytes and displays them in some meaningful fashion.
Anyway, congratulations on your achievement! I didn't know it was possible to access the serial port in QBASIC. Good job!
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 02-02-2004, 20:07
FRC #0030
Thanks Jeff,
Also, thanks KevinB. The ASC$ function was able to help me display the data correctly. I had never used that function before.
As soon as I make some good, usable dashboard code in Qbasic, I will post it. I am having a number of problems, such as the program crashing Windows 9x machines if it is run when the OI is off. Also, occationally the computer is unable to synchronize with the input frame of 26 bytes (especially if at least one byte is a 255) and displays garbage for a few frames.
Now I have a question for programmers out there. Qbasic is not particularly suited to visualization. I was only planning on using it to read the data from the serial port and feed it into something fancier. No Screenmode 13 graphics here =).
I was planning on having Qbasic output data into textfiles, stored on a Ramdisk. Then, I was thinking of using a few perl scripts and a webserver, to have the data available in a web browser. Can any of you tell me about any different (better) schemes for showing off data?
Team 30, 2002-2005
Unread 02-02-2004, 20:58
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
In the off-season, a friend of mine and I came up with a system where we wrote all the data to 40 or so different text files in order, then overwrote the first one again every second or so, and so on. Then we used Macromedia Flash (much more suited to visualization) to read the files and display the data.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 02-02-2004, 21:31
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
You can do it a lot easier than this Just put a Macromedia Flash ActiveX control on the form in VB (or Delphi, or any other environment that supports ActiveX). You can then set variables in the Flash movie directly. The Flash movie can interact with your program using the fscommand() function.
Unread 02-02-2004, 21:40
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
If you can handle C or C++, you could write a frontend that uses OpenGL or some other graphics library to display the collected data in real time.
Unread 02-02-2004, 21:43
Guest
Posts: n/a
In C/C++ combine OpenFile with ReadComm/WriteComm.
In VB, use the MSComm control.
Exact code can be found at Microsoft's MSDN:
http://msdn.microsoft.com/
Unread 04-02-2004, 07:34
AKA: Jamie Bliss
There are OpenGL (And DirectX, VB only compiles to windows) for VB.
If you can get a hold of a licensed version of the MSComm, You can put it in VBA. In word, open the Visual Basic toolbar, and press "Visual Basic Editor". It's not quite the same, but close enough. If anyone wants to know how to use the MSComm for dashboard, Ask and I'll send some sample code I got from this site.
I have a hunch that the terminal window in the IFI_Loader just outputs what it receives from the COM port (Ascii characters, no interpretation). Can any anyone deny/confirm this?
Unread 12-02-2004, 16:47
Camel85kv Camel85kv is offline
Camel85kv is an unknown quantity at this point
I wrote a Qbasic Dashboard program and it works well enough to share.
It
-detects packets
-saves the data into an array
-performs basic processing of the data
-displays data on screen
-cleanly handles COM port errors
Right now it is set up to read the OI, not the RC. Simply modify the "SELECT CASE 4" by changing it to "SELECT CAES packnum" in one of the subs to use the RC data instead. This is untested. There might be a bug with the PacketFrame!() Function.
If you simply load this program and run it, it may take two or three tries to connect. Just tell it to retry a few times. You should set Qbasic (or the compiled program) to run on compatibility mode for windows 98 if you are running XP. Windows XP does werid things to the COM port... To do this, right click on icon, properties, (etc).
If you use this code, please let me know and mention team 937. I don't check this board often, so email questions to kvogt {AT} everestkc.net.
-Kyle Vogt
-Team 937
Unread 12-02-2004, 17:27
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Heres a link to the dashboard program.
http://www.innovationfirst.com/FIRST...board_Spec.pdf
___________________________
If all else fails, use a bigger hammer.
Unread 12-02-2004, 17:57
FRC #0030
I like your code, Camel85kv. Thanks for the file.
For those of you unable to open the file, it was saved with QuickBASIC 4.5 (not QBASIC). I have QuickBASIC (purchased it years ago), but I recognize the fact that very few people do. I am posting a text version of Team 937's fine work here. The text version is compatible with QBASIC.
Team 30, 2002-2005
Unread 12-02-2004, 18:04
Thanks for the kind words! You are right, QuickBasic is a bit harder to find than the original QBasic. I'm glad you pointed that out because that file is jibberish to people without QuickBasic. Let me know if something does not work.
-Kyle Vogt
-Team 937
Creating a dashboard program Jeff_Rice Programming 18 04-05-2003 23:21
Custom dashboard program available. Interest? archiver 2001 4 24-06-2002 00:45
miroboworks dashboard program? archiver 2000 3 23-06-2002 23:04
CCISD Updated Dashboard program v2.2.1 archiver 2000 3 23-06-2002 21:57
Yet another dashboard program Neal Probert Programming 3 12-05-2002 10:43
