Go to Post You should never, EVER bully, manipulate, or slander another team for the sake of winning. - Libby K [more]
Unread 31-01-2004, 12:43
Mercutio Mercutio is offline
Atticus Finch Wannabe
#1213 (The Grobots)
Mercutio is on a distinguished road
More than two air tanks?
We've been in FIRST for two years, so we have four pneumatic accumulator tanks -- one set from this year and one set from last year. In the rules, it says that "there is no limit to the number of solenoid valves, air cylinders, and connecting fittings you may use on your robot," but it also says that "the pneumatic system uses compressed air from a 12V DC powered compressor that discharges into two air storage tanks." Are we allowed to use more than two tanks on our robot? I don't think there would be a safety concern, since all the pressures in the system would remain the same.
~Aaron
"If we knew what we were doing, it wouldn't be called research, would it?"
—Albert Einstein
<X3 What can I do? You broke the tie wraps that were holding together my heart. ^_^
Unread 31-01-2004, 13:03
inwoodraider inwoodraider is offline
inwoodraider is an unknown quantity at this point
Re: More than two air tanks?
For the pneumatics set up, you can only use the two air tanks that they provide you with every year. You can use as many cylinders as you want but only those air tanks.
Tyler
Team 1155
Unread 31-01-2004, 14:05
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
This is true, however if you really need more air, you can use additional pistons as air tanks. The only catch is that they can only be filled to 60psi.
Zan Hecht
Unread 31-01-2004, 18:59
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
You can also use a coil of tubing - it has more volume than your would expect and could be on the 120 psi side of the regulator.
EDIT / ERROR - According to FIRST Q & A, you cannot use a coil of tubing to store air.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 01-02-2004, 01:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What about using cylinder to store air (at 60 psi of course)? Would this be legal?
EDIT: I found the Q&A post and that person was asking if we can use coiled tubing in place of the tanks. What about in additon to the tanks? You already need a piece of tubing between the tanks and regulator, so what difference would it make if it was oh, say 6' longer?
Unread 10-02-2004, 16:00
platt platt is offline
FRC #1345
platt is an unknown quantity at this point
are we allowed to use parts for pnematics that was not provided to us and is there a restriction on how to wire
Unread 10-02-2004, 16:07
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
RTFM [Read the First Manual]
Both of your questions are answered in it. You are allowed to use additional pnuematic cylinders as long as they are identical to the ones on the bimba order sheet. You are also allowed to use previous year's solenoids or their equivalent. You are not allowed to use other components unless specifically allowed by FIRST.
As to wiring, all the info you'll ever need to know is located in the FIRST manual. Read it. Understand it. Love it.
Use of tanks from prior years. Alex N. Pneumatics 6 13-01-2004 22:19
Where to get air muslce pneumatics? Adam Y. Pneumatics 5 27-12-2003 23:17
Pneumatics and last year's storage tanks Darwin695 Pneumatics 3 04-02-2003 02:13
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
Air Fare to Florida archiver 2000 0 23-06-2002 22:16
