Go to Post ... if there is no standard against which you determine success, then you can never fail. - dlavery [more]
Unread 31-01-2004, 20:23
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Pneumatic Tubing Question
As I read Section 5.2.9 of the manual (Rules R53 and R54), and go through the Part Use Flowchart, I would interpret it as "no". Alternative tubing is not a kit part, so it falls under the "Pneumatics/Hydraulics" section. It is not an air cylinder listed on the Custom Cylinder Order Form, or a component from a prior year's kit. Therefore, the logic flows to the "No, it may not be used" box.
Note this is not an official answer, only my opinion. For the real answer, post this to the FIRST Q&A board. But this is what I would expect the reponse to be.
-dave
A question about control system options computhief263 Control System 7 04-02-2004 14:46
LAST MINUTE Pneumatic Question archiver 2001 6 24-06-2002 01:11
latex tubing rules?? Christina Technical Discussion 4 21-02-2002 18:43
Wire running question DanBlock Electrical 7 17-02-2002 03:37
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
