Go to Post Don't give up on others. I believe in killing grumps with a smile! - maltz1881 [more]
Unread 29-01-2004, 00:02
doy's Avatar
doy doy is offline
#1208 Ex-Lead Programmer
AKA: Jesse Luehrs
#1208 (The Super Critical Axe Men)
doy is on a distinguished road
Send a message via AIM to doy
number of joysticks
looking through the rules, i didnt notice anything that mentioned the number of joysticks we are allowed to use... are we allowed to use more than 2 joysticks to control the robot? im assuming thats why we have 4 input ports, but i just wanted to make sure.
Unread 29-01-2004, 00:03
Umm Errr...
Re: number of joysticks
In previous years yes. I'm assuming the same is true this year.
1139 Alumni
Unread 31-01-2004, 21:07
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
I saw something on the FIRST Q & A about there not being a limit to what you can use, but since there are only 4 ports, you can only use up to four.
The only thing is, FIRST sent two right handed joysticks, which makes it odd for the driver...
Unread 31-01-2004, 21:13
Guest
Posts: n/a
In previous years, there were four input ports, also. However, I think two of them are "dummy" inputs. As in port 3 is the same as port 1 (same signals), and port 4 is the same as port 2 (same signals). Or maybe 1=4 and 2=3, not sure. Check the Programming Reference guide and the FRC2004 OI Reference Guide from IFI.
Unread 31-01-2004, 22:09
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
There are 16 analog inputs and 16 digital inputs so if you use y cable on your joystick ports you can have 8 joysticks that each have two buttons and two axises of movement or any combination of switches and axises. As far as I can tell according to the rules this year you can modify the joysticks as well if you need not make a custom joystick for something.
Unread 01-02-2004, 00:05
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
This isnt true. Some of the buttons are repeated as additional pins on other ports, but you can get actual input from 4 analog axes and 4 digital inputs on all ports. (Yielding 16 total analog; 16 total digital)
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
team number... Ken Leung Chit-Chat 39 28-09-2003 14:36
Team Numbers archiver 2000 2 24-06-2002 00:24
WASH scouting fields Mike Soukup Scouting 0 04-02-2002 02:39
3 is the number and the number shall be 3... Joe Johnson General Forum 21 03-12-2001 17:08
