Go to Post Only time will tell for sure, but it seems that the current software providers are hatching up a pretty good solution to the problem. - dlavery [more]
Unread 01-02-2004, 20:03
punarhero's Avatar
punarhero punarhero is offline
#0696 (Clark Magnet Robotics)
punarhero is an unknown quantity at this point
Send a message via AIM to punarhero Send a message via Yahoo to punarhero
A robot Audio System
Hi all,
Our team has a project to build a robot for a museum. The robot is supposed to go to each picture, autonomously, and play a pre-recorded info. Well, our problem is what to use for the audio system. What we had thought of doing is keep a count of the picture number the robot is at, and play a corresponding track on our audio system. But there are several problems:
1. If we use a tape-recorder, we can turn the tape on when the robot is at a picture, keep time of how long it takes to play each track, then turn it off. This way we can play each track with each picture. the problem is that a tape recorder is not user friendly, and someone who wants to change a small part of the tape will have to go thorough a lot of prouble.
2. We could use a CD player, but once we turn it off, it starts off at the first track.
So, we wanted something that we can connect to a relay, turn it on and off according to the picture we are at, and play a corresponding audio track. Any suggesstions?
Punar Sikka
Team 696
www.team696.org
Unread 01-02-2004, 20:21
Bill-Boelk Bill-Boelk is offline
play all day, work at night
FRC #0930 (Mukwonago B.E.A.R.S.)
Bill-Boelk is an unknown quantity at this point
Send a message via AIM to Bill-Boelk
Re: A robot Audio System
put bar codes on the wall and digitally store the information inside your robot. as the robot get to the picture it scans the barcode and plays your info.
Mukwonago Team 930
Midwest Regional 2nd Place 2003
Midwest Regional Champs 2004
College Mentor
Milwaukee School of Engineering '11
Unread 01-02-2004, 20:57
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
how long of an audio clip is it? if it's not a long speach or something, I think you could just use a series of recordable sound chips with some fancy wiring into some speakers. Here's a link:
Sound Chips
a little dilligent searching could probably turn up some other chips with a little more capacity.
Edit:
In fact there's a link at the bottom of the page to a much more versatile and capacious setup.
Unread 01-02-2004, 21:27
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
with most current models of portable cd players, the cd resumes after stopage. another option would be to just pause the player instead of stopping it.
Unread 01-02-2004, 22:29
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
You could use smart chips so that you wouldnt need the robot to look for a barcode on the wall, lots of places use smart chips now they work some way i dont know, do some research.
You could use a vision recognition system like the CMU Cam
http://www.acroname.com/robotics/par...MUCAM-KIT.html
Also you could use a robot controller that is a single board computer, like the Via mini ITX robotics system
http://robots.net/article/983.html
Then you can have it access files stored on a hard drive and it would solve some of the issues you are having, maybe even just using an Mp3 player with your system in general. There are lots of websites about people building thier own Mp3 players im sure you can find somehing that will help you.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 01-02-2004, 22:43
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
Following up on Andrew's post, using a full computer could also give you the advantage of some modern OCR systems for text recognition...who needs smart chips and bar codes when you can just read the title?
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 01-02-2004, 23:24
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
Depending on how long each audio recording needs to be, you could use a Winbond addressable recorder chip (http://dkc3.digikey.com/pdf/T041/0301.pdf) to store the recordings and a microcontroller to trigger each message at the appropriate location. Distance measurement could easily be performed using encoders attached to your drive wheels.
Unread 01-02-2004, 23:46
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
IF you were using an entire computer doing ocr you could use winamp to play mp3 files of what you want to say from a cd... and I would reccomend using line following to navigate, and watch for obsticals... such as ppl, little kids.. ect.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 02-02-2004, 00:00
Git 'em!
Yeah you definetly need to have some sort of obstacel avoidance system. you could set up a system of way points much like GPS systems work using encoders to constantly track the position of the bot. Maybe you could use one of the cye robots, they have a great waypoint system
http://www.personalrobots.com/
Robot in 3 Days
Unread 02-02-2004, 19:19
Umm Errr...
Originally Posted by punarhero
Hi all,
How long are the clips? There are voice recorder ICs, that are basically a single chip sound clip player. I think radio shack even sells them.
You could also wire a relay up to the next track and pause butins of a CD player. You could also use a computer or palm pilot with audio capibilities, wihc could double as the robot controller.
1139 Alumni
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Image Discuss: 810 - Minotaur: Coming to a regional near you. CD47-Bot Robot Showcase 47 25-02-2003 16:19
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Teams with cool sound system on their robot... Lethi86 Regional Competitions 2 18-03-2002 01:35
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
