Re: smoking drill motors?
Last year in a match at nationals one of our wires desoldered itself from the drill motor. It didn't break off, you could actually see the hole where it used to be soldered. They were the original blue wires too. We never used a soldering iron on them at all. This was after several elimination matches in a row, so they got very hot even though we did our best to cool them down between matches.
They desoldered themselves again in the summer while we were demonstrating the robot to some people. |
Wetzel |
My team just had this problem last night. We were driving the robot around for some testing, and about 3-4 minutes of driving it around on a cement area in the middle of our school, we noticed smoke from the motors. We checked it out and there was definitely smoke coming from the motors and a very strong smell of it. We have one large muffin fan mounted above each drill motor, although we noticed a large amount of escaped airflow, we thought this might be the problem, so today we are going to fabricate some air ducts. Does anyone else have any suggestions? We did not disassemble the motors and I do not believe there was any drilling on the chassis around the motors.
Also, we noticed that there was a lag with one wheel, so it skips three or four times at acceleration and then moves slower than the other wheel as we drive around. I know that the other wheel's gearbox is greased up, and this one's isn't. Does anyone know what else might cause this problem? ![]() |
This is very typical of some designs. You do not say what your configuraion is so I am going to assume four wheel tank or two wheel with non steering two front wheel. These types of drive systems use incredible amounts of current when turning. Again, if there is any friction in your drive train it will manifest itself as high current in the drill motors. Can you describe the drive train or include a picture?
Thanks for your help. |
#7
Do you have your gear boxes aligned so that when the bot is going forward, both motors are going in their forward direction? Or is one going forward and the other in reverse? If this is the case, that would explain the lag between the two wheels. These motors are more efficient when run in the forward direction, so if one runs opposite the other it will do so unevenly. |
#8
Our 2001 drill motors would smoke quickly whenever we stalled them (like driving into a wall, and maintaining full power to the motors). The 2004 motors are different, but I suspect they would do the same.
| Complete Drill, Seat, and Window motors for trade | archiver | 2000 | 0 | 23-06-2002 22:16 |
| Blowing drill motors | archiver | 2000 | 6 | 23-06-2002 21:58 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| what about the drill motors? | Ken Leung | Motors | 2 | 26-06-2001 02:11 |
