Go to Post I think sportsmanship is only one facet of the gp diamond. - Redhead Jokes [more]
Unread 01-02-2004, 22:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Can this be turned on a lathe?
Can this be turned on a lathe? The diameter of the hub is currently 2.25 and we need it down to 1.25. What will happen when the edges of the cutouts hit the lathe cutter? If we can't do it in the lathe, how do we reduce the diameter? Circular pattern in the CNC? Also, if we can do it in the lathe, how much should we take on each cut and what sort of speed might we use? Thanks.
Unread 01-02-2004, 22:46
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Re: Can this be turned on a lathe?
The short answer is: there's a whole lot more you need to know about cutting speeds and feed rate. It really depends on the material the gear is made out of. If it's a hardened spur gear, you can have quite a bit of trouble cutting the material itself.
As for the lathe hitting the drilled out edges, it's a dynamic forces sort of thing since the metal will continually be engaging metal as it spins. I could honestly see this as a, "it's no big deal" or "don't you dare try to lathe that!" situation. You might be better off to just 2nd day ship out the gear(s) and lathe it down.
If you're just looking to reduce weight, it's just a matter of ounces you're looking at since you already have a fairly nice bolt patern in there... is it really worth it?
(I know, it's always worth it when you're 3 ounces over weight. It's also worth it if the hub is interfering with another component)
Anyway, hopefully you'll be able to post a little more information about the gear so that a machinst can throw out some speed and feeds for you, especially in this situation.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 01-02-2004, 22:56
Well, the gear is a steel Martin gear. As for it being hardened, I have no idea. All I know is that it was not too hard to drill. It needs to be turned down to fit in our gearbox. If we don't turn it down, we would have to face the hub off to like .125 (which would make it fit in our gearbox) but we'd rather leave the width of the hub since we were concerned about it wobbling on the shaft. It is a 60T 20P gear and having it only .625 wide total might make it want to wobble up near the teeth. We are having a pretty tight fit on the shaft but still the more width you have the more guarantee that it is straight.
Can someone provide a little more specific answer as to whether or not we can turn this?
Also, if we cannot lathe it, how hard would it be to have it go around a mill bit in the CNC mill in a "circular spiral" pattern until the correct diameter is reached?
Unread 01-02-2004, 23:35
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Yes, this can be done. Contact a local community college or occupational school and ask to talk to the machining teachers. They should be able to give you all of the information you need.
indieFan
Unread 02-02-2004, 01:28
We have the full machine shop of our local community college available to us. I am probably the most experienced student machinest on our team (having done it for over two years now) but I just have never turned anything like this. I've done hex and square bar just fine but that is not so jagged really. We'll be going in tomorrow and I'll give it a try.
Unread 02-02-2004, 02:18
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Yes, you can do it, but you are probably going to want to do it in two steps.
The first part of the cut will be an interrupted cutting operation. This is rather hard on carbide tool bit, so I would recommend using a "standard" tool steel cutting bit, with very light rake (you want all the support for the cutting edge that you can get). If this is one of the standard Martin gears made of 303 Steel, then you will want a surface cutting speed of about 50 ft/min. For a 2.25 inch diameter gear hub this works out to about 85 rpm. Since it is an interrupted cut, you would be safe to slow it down by another 20%. In other words, cut slowly and cut shallow (about 0.010" - 0.015" per pass if you are using a small lathe [1-1/2HP or less]). The tool steel bit should stand up under the shock loads and last long enough to get past the bolt holes.
Once you are down to a smooth cut, switch to a carbide bit. Crank up the surface cutting speed to about 150 ft/min. You should be able to increase the cut depth to 0.030" per pass. You will get through the rest of the cut a lot faster.
Since you are doing this as a "one-off" these numbers are close enough to do the job. If you were going to do 10,000 of these as a production run and were concerned about the very best optimum cutting speeds and maximizing tool life and overall productivity rates, then there would be a lot more we would have to talk about. But for this type of work you should be all set. Good luck!
-dave
Unread 02-02-2004, 08:46
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Another option would be to do this on a rotary table on a mill. You might want to check with the shop if they have one.
Unread 02-02-2004, 12:46
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
If the gear is hardened, it will probably only be locally flame hardened in the area of the teeth. Since you appear not to be messing with the teeth it shouldn't be a problem.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 02-02-2004, 19:10
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
Yes its easy to machine in a lathe, use a collet to hold the part by the gear side. No the collet wont hurt the gear teeth. you should be able to machine it, doens't look like it has been harden. As for the cutting tool hitting the gaps, dont worry about it, just go slow with your feed, the speed the cutting tool moves at. You could probably get away with an rpm of 100 or a little more. Thats what i would do. Any questions or complication just ask.
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
For those of you who turned off MNF and went to bed.... D.J. Fluck Chit-Chat 11 08-10-2003 23:30
Who turned in their chairmans at UCF? ComBBAT_Amy Chairman's Award 2 18-03-2003 20:27
Grizzly Lathe Opinons Caroline General Forum 7 28-08-2002 18:55
cutting wheels archiver 2001 3 23-06-2002 23:52
Location, location, location... archiver 1999 10 23-06-2002 23:02
