Go to Post You don't always get what you pay for, but you hardly ever get what you don't pay for. - MrForbes [more]
Unread 02-02-2004, 01:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Can this be turned on a lathe?
Originally Posted by indieFan
Yes, this can be done. Contact a local community college or occupational school and ask to talk to the machining teachers. They should be able to give you all of the information you need.
We have the full machine shop of our local community college available to us. I am probably the most experienced student machinest on our team (having done it for over two years now) but I just have never turned anything like this. I've done hex and square bar just fine but that is not so jagged really. We'll be going in tomorrow and I'll give it a try.
Unread 02-02-2004, 02:18
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Yes, you can do it, but you are probably going to want to do it in two steps.
The first part of the cut will be an interrupted cutting operation. This is rather hard on carbide tool bit, so I would recommend using a "standard" tool steel cutting bit, with very light rake (you want all the support for the cutting edge that you can get). If this is one of the standard Martin gears made of 303 Steel, then you will want a surface cutting speed of about 50 ft/min. For a 2.25 inch diameter gear hub this works out to about 85 rpm. Since it is an interrupted cut, you would be safe to slow it down by another 20%. In other words, cut slowly and cut shallow (about 0.010" - 0.015" per pass if you are using a small lathe [1-1/2HP or less]). The tool steel bit should stand up under the shock loads and last long enough to get past the bolt holes.
Once you are down to a smooth cut, switch to a carbide bit. Crank up the surface cutting speed to about 150 ft/min. You should be able to increase the cut depth to 0.030" per pass. You will get through the rest of the cut a lot faster.
Since you are doing this as a "one-off" these numbers are close enough to do the job. If you were going to do 10,000 of these as a production run and were concerned about the very best optimum cutting speeds and maximizing tool life and overall productivity rates, then there would be a lot more we would have to talk about. But for this type of work you should be all set. Good luck!
-dave
Unread 02-02-2004, 08:46
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Another option would be to do this on a rotary table on a mill. You might want to check with the shop if they have one.
For those of you who turned off MNF and went to bed.... D.J. Fluck Chit-Chat 11 08-10-2003 23:30
Who turned in their chairmans at UCF? ComBBAT_Amy Chairman's Award 2 18-03-2003 20:27
Grizzly Lathe Opinons Caroline General Forum 7 28-08-2002 18:55
cutting wheels archiver 2001 3 23-06-2002 23:52
Location, location, location... archiver 1999 10 23-06-2002 23:02
