Go to Post It's a good things we're engineers who regularly squeeze out 'miracles' with a severely limited budget, eh? I think that's an important aspect that we as mentors need to show the students from time to time, and this year is a perfect opportunity. - JesseK [more]
Unread 30-01-2004, 00:34
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Initializing autonomous mode
I'm sure this is quite a newbie question, but here goes:
Before a match starts, what state is the robot in?
i.e. Powered On - Radios Active (program running), Autonomous Mode, but Disabled...
or Powered On - Radios Active (programming running), Operator Mode, but Disabled...
or Powered On - Radios not Active (program not running)...
or etc...
The reason is I'm unsure of how to initialize autonomous mode. I'm concerned that the autonomous program might be running before the match actually begins. And if you have some kind of dead-reckoning involved at the start, it'll get all messed up.
Can someone give me a quick lowdown of exactly how the robot states are setup pre-match, and what happens at the start of the match? Hell, detail the transition from autonomous to operator mode too if it's not as obvious as it should be =).
-Shawn...
Unread 30-01-2004, 00:43
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Initializing autonomous mode
I believe it's something near your second case, but I may be mistaken. Chances are good that autonomous_mode is a true value only during the actual autonomous mode.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 30-01-2004, 00:52
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
I have the system right in front of me and it prints out status and this is what it says:
When "disabled" the user code is in normal mode, running the normal mode loop, reading operator inputs, writing outputs, etc. but all outputs are disabled.
This is regardless of whether the autonomous switch is set or not (IFI dongle)
If the autonomous switch is set, the user code transitions into autonomous mode when the disable is removed.
Unread 30-01-2004, 01:26
AKA: Mr. Lim
Thanks for the quick responses! That answers all my questions!
Unread 30-01-2004, 14:09
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Sort of half related: If the OI is unplugged, no code executes.
Unread 31-01-2004, 16:45
Code\\Pilot Code\\Pilot is offline
< Only smart people see my avatar
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Code\\Pilot is an unknown quantity at this point
Send a message via AIM to Code\\Pilot Send a message via MSN to Code\\Pilot
I had the same question once, but i managed to figure it out.
In the OI you can see that you have many ports, and one of those ports is the competition port, through the competition port the referis can stop your robot and activate autonomous. You can make a simulation of the initiation messing with that port.
Here is a link that tells you how:
http://www.innovationfirst.com/FIRST...umentation.htm
it takes to the documentation of innovationfirst.
Click in the link that says "Competition port pin-out guide".
That should help you.
Have fun!!!
Code\\monkey
Join the Red revolution, give me some RED rep!!!!
if it doesn't work, don't force it. Go get a bigger hammer.
int run = 0;
int robot_chasing_you = 1;
if (robot_chasing_you)
run = 254;
I got 48 Gmail invites left, pm me with your e-mail so i can send you one.
Unread 31-01-2004, 17:41
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Just to summarize as I understand it:
During the time before the match, the RC is ...
  • Powered On
  • Radios Active
  • Programming running
  • Disabled
I'm not sure if there is a set standard as to whether or not it is in "operator" or "autonomous" mode; with a dongle -- it is possible to change that mode setting while the robot is disabled.
Unread 02-02-2004, 07:26
AKA: Jamie Bliss
as the docs say: USE EXTREME CAUTION!!! Some pins on the Competition port go DRECTLY to the processor
test autonomous mode CharlieWilken Programming 14 20-02-2004 00:39
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
